メインコンテンツまでスキップ
OCI のインストールエラー: MySQL を起動できません
29
Visibility:
Votes:
0
Category:
oncommand-insight
Specialty:
oci
Last Updated:
に適用されます
OnCommand Insight ( OCI ) AKA SANscreen の略
問題
OCI のインストールサーバに障害が発生した
入力  SANscreen\bin\log\install.mysql.log:
Checking for listener at localhost:3306
waitfor: timeout
[ant] Exiting C:\Program Files (x86)\SANscreen\bin\server.xml.
BUILD FAILED
C:\Program Files (x86)\SANscreen\bin\setup.xml:175: The following error occurred while executing this line:
C:\Program Files (x86)\SANscreen\bin\server.xml:81: Failed to start mysql
at org.apache.tools.ant.ProjectHelper.addLocationToBuildException(ProjectHelper.java:541)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:418)
at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:288)
at sun.reflect.GeneratedMethodAccessor2.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.apache.tools.ant.dispatch.DispatchUtils.execute(DispatchUtils.java:105)
at org.apache.tools.ant.Task.perform(Task.java:348)
at org.apache.tools.ant.Target.execute(Target.java:357)
at org.apache.tools.ant.Target.performTasks(Target.java:385)
at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1329)
at org.apache.tools.ant.Project.executeTarget(Project.java:1298)
at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:41)
at org.apache.tools.ant.Project.executeTargets(Project.java:1181)
at org.apache.tools.ant.Main.runBuild(Main.java:698)
at org.apache.tools.ant.Main.startAnt(Main.java:199)
at org.apache.tools.ant.launch.Launcher.run(Launcher.java:257)
at org.apache.tools.ant.launch.Launcher.main(Launcher.java:104)
Caused by: C:\Program Files (x86)\SANscreen\bin\server.xml:81: Failed to start mysql
at org.apache.tools.ant.taskdefs.Exit.execute(Exit.java:142)
at org.apache.tools.ant.helper.SingleCheckExecutor.executeTargets(SingleCheckExecutor.java:38)
at org.apache.tools.ant.taskdefs.Ant.execute(Ant.java:416)
... 16 more
--- Nested Exception ---
Total time: 10 minutes 7 seconds
New to NetApp?
