メインコンテンツへスキップ
VI SDK の呼び出し例外が原因で、 SCV バックアップジョブが「 Unable to quiesce on SCV 」で失敗する
688
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2008587031</a>
Last Updated:
環境
SnapCenter Plug-in for VMware vSphere ( SCV ) 4.3.1
問題
  • SCV バックアップジョブが「Unable to quiesce on SCV」というメッセージで失敗する。
Task 'Quiescing Applications' failed with error: Unable to quiesce on SCV: Exception occurred when quiescing virtual machines: <VM_NAME>.
  • vmcontrol_<JOB_ID>.log CreateSnapshot_Task は、例外 ""VI SDK invoke exception:java.net.SocketTimeoutException: connect timed outを検出したことを示します。
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.b.QuiesceManager           : Getting VM Snapshot Name: <VM_SNAPSHOT_NAME>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.b.QuiesceManager           : VM [<VM_NAME>] is powered ON. Taking VMware snapshot with name: <VM_SNAPSHOT_NAME>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereInventoryService      : Looking for VM with instance UUID <UUID>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereService           : [JobId:<JOB_ID>] Connecting to vSphere with session <SESSION_ID>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereInventoryService      : [JobId:<JOB_ID>] found the VM <VM_NAME> VirtualMachine:vm-XXXX @ https://<VCENTER_HOST>:443/sdkwith instance uuid found <UUID>
DEBUG <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereService           : VsphereUtils: Monitoring Task CreateSnapshot_Task
 WARN <HOST> --- [ol-114-thread-1] c.n.a.v.VsphereSnapshotService       : [JobId:<JOB_ID>] Got Exception while creating snapshot '<VM_SNAPSHOT_NAME>' : java.rmi.RemoteException: VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out
  • 例外 ""VI SDK invoke exception:java.net.SocketTimeoutException: connect timed outもに表示さ vmcontrol_jetty_server.logれます。
INFO  SCV root java.lang.RuntimeException: java.rmi.RemoteException: VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out
INFO  SCV root    at com.vmware.vijava.vim25.mo.ManagedObject.retrieveObjectProperties(ManagedObject.java:158)
INFO  SCV root    at com.vmware.vijava.vim25.mo.ManagedObject.getCurrentProperty(ManagedObject.java:179)
INFO  SCV root    at com.vmware.vijava.vim25.mo.Task.getTaskInfo(Task.java:62)
INFO  SCV root    at com.netapp.aegis.vsphere.VsphereService.waitForTaskCompletion(VsphereService.java:149)
INFO  SCV root    at com.netapp.aegis.vsphere.VsphereSnapshotService.createSnapshot(VsphereSnapshotService.java:48)
INFO  SCV root    at com.netapp.aegis.backup.QuiesceManager.quiesceVM(QuiesceManager.java:205)
INFO  SCV root    at com.netapp.aegis.backup.QuiesceManager$1.run(QuiesceManager.java:122)
INFO  SCV root    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
INFO  SCV root    at java.util.concurrent.FutureTask.run(FutureTask.java:266)
INFO  SCV root    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
INFO  SCV root    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
INFO  SCV root    at java.lang.Thread.run(Thread.java:748)
INFO  SCV root Caused by: java.rmi.RemoteException: VI SDK invoke exception:java.net.SocketTimeoutException: connect timed out
INFO  SCV root    at com.vmware.vijava.vim25.ws.WSClient.invoke(WSClient.java:101)
INFO  SCV root    at com.vmware.vijava.vim25.ws.VimStub.retrieveProperties(VimStub.java:73)
INFO  SCV root    at com.vmware.vijava.vim25.mo.PropertyCollector.retrieveProperties(PropertyCollector.java:107)
INFO  SCV root    at com.vmware.vijava.vim25.mo.ManagedObject.retrieveObjectProperties(ManagedObject.java:155)
INFO  SCV root    ... 13 more
  • エラーメッセージUnable to quiesce on SCV"" は wfe_<JOB_ID>.logにあります。
DEBUG <HOST> --- [    Thread-111] c.n.w.u.LogHelper             : Starting Quiesce activity
DEBUG <HOST> --- [    Thread-111] c.n.w.r.SCVBackupServiceImpl        : Quiesce on SCV
DEBUG <HOST> --- [    Thread-111] c.n.w.r.u.RestClientUtil          : Connecting to scv url: https://localhost:8144/scbr/smcoreplugin/quiesce
ERROR <HOST> --- [    Thread-111] c.n.w.r.SCVBackupServiceImpl        : Unable to quiesce on SCV: Exception occurred when quiescing virtual machines: <VM_NAME>.Please check 'Create virtual machine snapshot' task on vSphere Web Client or SnapCenter Plug-in for VMware vSphere logs for detailed error message.
New to NetApp?
