メインコンテンツへスキップ
アップグレード後にSCVメンテナンスコンソールに「setting locale failed」と表示される
47
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009742091</a>
Last Updated:
環境
  • SnapCenter Plug-in for VMware vSphere ( SCV )
  • SCVを4.6P1以前にアップグレードしたあと
問題
SCVのメンテナンスコンソールにログインすると、次の警告が 表示されます。
 Maintenance Console : "SnapCenter Plug-in for VMware vSphere"
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
     LANGUAGE = (unset),
     LC_ALL = "en_US.UTF-8",
     LANG = (unset)
   are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
     LANGUAGE = (unset),
     LANG = (unset)
     LANGUAGE = (unset),
     LANG = (unset)
 Discovered interfaces: eth0 (ENABLED)
 Main Menu:
   1 ) Application Configuration
   2 ) System Configuration
   3 ) Network Configuration
   4 ) Support and Diagnostics
   x ) Exit
 Enter your choice:
New to NetApp?
