メインコンテンツへスキップ
SCW が WSFC ノード Other で共有ディスクを作成できません クラスタ所有者ノードが含まれます
61
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
環境
  • SnapCenter Server 4.3 以前
  • SnapCenter Plug-in for Microsoft Windows ( SCW ) 4.3 以前
  • Windows Cluster GroupAvailable StorageServer フェイルオーバーでは、の所有者ノードが異なります クラスタリング( WSFC )
問題
  • SCW がエラーFailed - Failed to create windows file system Failed to create partition [ Error Code: 41000]"" で共有ディスクを作成できません。
  • SCWDebug.log に、クラスタ所有者ノードを示します Error Code: 41000PartitionManager::CreateWindowsFileSystem
Verbose SDW PID=[<PID>] TID=[<TID>] ++PartitionManager::CreateWindowsFileSystem
Verbose SDW PID=[<PID>] TID=[<TID>] ++CmdletDiskManagementStrategy::InitializeDisk
Verbose SDW PID=[<PID>] TID=[<TID>] ++CmdletDiskManagementStrategy::CreateRunspace
Verbose SDW PID=[<PID>] TID=[<TID>] Creating remote runspace
Verbose SDW PID=[<PID>] TID=[<TID>] --CmdletDiskManagementStrategy::CreateRunspace
Error SDW PID=[<PID>] TID=[<TID>] Failed to initialize the disk: error = Connecting to remote server <HOST> failed with the following error message : The server certificate on the destination computer (<HOST>:5985) has the following errors:
Encountered an internal error in the SSL library. For more information, see the about_Remote_Troubleshooting Help topic.
Verbose SDW PID=[<PID>] TID=[<TID>] --CmdletDiskManagementStrategy::InitializeDisk
Verbose SDW PID=[<PID>] TID=[<TID>] ++WmiHelper::IsWindowsServer2019
Verbose SDW PID=[<PID>] TID=[<TID>] --WmiHelper::IsWindowsServer2019
Verbose SDW PID=[<PID>] TID=[<TID>] Creating partition...
Error SDW PID=[<PID>] TID=[<TID>] Failed to create partition [ Error Code: 41000]
Error SDW PID=[<PID>] TID=[<TID>] Failed to create windows file system
Verbose SDW PID=[<PID>] TID=[<TID>] --PartitionManager::CreateWindowsFileSystem
Error SDW PID=[<PID>] TID=[<TID>] Failed to provision disk
Error SDW PID=[<PID>] TID=[<TID>] Failed to create windows file system   at SnapDrive.Nsf.Core.Host.PartitionManager.CreateWindowsFileSystem(CreateWindowsFileSystemRequest request)
  at SnapDrive.Nsf.Core.DiskProvisioningManager.SDProvisionCreateStorage(SDProvisionCreateStorageRequest request, DiskOperationContext context, Boolean provisioning)
New to NetApp?
