MySQLサービスがSnapCenterサーバで起動しない
環境
- SnapCenter Server 5.0
- SnapCenter Server 6.0以降
- MySQL Server
問題
- SnapCenter サーバのクラッシュまたは強制再起動後に MySQL サーバサービス(
MySQL57)を開始できない - SC PowerShell(6.x)または PowerShell(5.0)からの
Open-SmConnectionが正常に接続されない - SnapCenter サーバの Windows アプリケーションイベントビューアログに次のエラーが表示される:
エラー1:
Application Error,1000,"Faulting application name: mysqld.exe, version: 8.0.35.0, time stamp: 0x6527ffa1
Faulting module name: ntdll.dll, version: 10.0.14393.6343, time stamp: 0x6502806a
Exception code: 0xc0000006
Fault offset: 0x0000000000035d7d
Faulting process id: 0xe5c
Faulting application start time: 0x01da92cf32658aa9
Faulting application path: C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe
Faulting module path: C:\Windows\SYSTEM32\ntdll.dll
Report Id: d0600452-fe7e-4e74-9593-7e9d20408038
Faulting package full name:
Faulting package-relative application ID: "
Application Error,1005,"Windows cannot access the file C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe for one of the following reasons: there is a problem with the network connection, the disk that the file is stored on, or the storage drivers installed on this computer; or the disk is missing. Windows closed the program mysqld.exe because of this error.
Program: mysqld.exe
File: C:\Program Files\MySQL\MySQL Server 8.0\bin\mysqld.exe The error value is listed in the Additional Data section.
User Action
1. Open the file again. This situation might be a temporary problem that corrects itself when the program runs again.
2. If the file still cannot be accessed and
- It is on the network, your network administrator should verify that there is not a problem with the network and that the server can be contacted.
- It is on a removable disk, for example, a floppy disk or CD-ROM, verify that the disk is fully inserted into the computer.
3. Check and repair the file system by running CHKDSK. To run CHKDSK, click Start, click Run, type CMD, and then click OK. At the command prompt, type CHKDSK /F, and then press ENTER.
4. If the problem persists, restore the file from a backup copy.
5. Determine whether other files on the same disk can be opened. If not, the disk might be damaged. If it is a hard disk, contact your administrator or computer hardware vendor for further assistance.
Additional Data
Error value: C0000185
Disk type: 3"- SnapCenterサーバーのGUIに、次のいずれかのエラーでアクセスできません:
エラー1:
SnapCenter repository is not accessible. Error: Can't connect to MySQL server on 'localhost' (10061):No connection could be made because the target machine actively refused it [::1]:3306
エラー2:
HTTP Error 500.30 – ASP.NET Core failed to start
