SnapCenter Plug-in for Oracle Databaseの検出で予期しない接続が発生しました
- 38
- Visibility:
- Public
- Votes:
- 0
- Category:
- snapcenter
- Specialty:
- snapx<a>SCO</a><a>2009605225</a>
- Last Updated:
環境
SnapCenter Plug-in for Oracleの略
問題
SnapCenter Plug-in for Oracleのバックアップまたは検出の実行時に、次のエラーが表示されて失敗します
EXE-00001: Shell result [0:00:00.221] (Exit Value: 127): -ksh: ./../plugins/sco/bin/launch-java: not found
DEBUG DisRes-NTAP1 c.n.c.l.MessageBundle - Loading resource bundle from com/netapp/common/remote/remote-messages for com.netapp.common.remote.MsgKeyERROR DisRes-NTAP1 c.n.c.r.RemoteObjectFactoryFactory - REMOTE-00001: Unable to connect to spawned helper process. Error: -ksh: ./../plugins/sco/bin/launch-java: not found
ERROR DisRes-NTAP1 c.n.o.c.c.AbstractDatabaseService - JDBC exception from AbstractDatabaseService:REMOTE-00001: Unable to connect to spawned helper process. Error: -ksh: ./../plugins/sco/bin/launch-java: not found
java.lang.RuntimeException: REMOTE-00001: Unable to connect to spawned helper process. Error: -ksh: ./../plugins/sco/bin/launch-java: not found
PL-SCO-20006: Discovery of database files failed for database NTAP1 on host <hostname> with error Operation Exception occured during oracle databaseconnection, reason: Unexpected Operation occured.
com.netapp.oracle.core.exception.OperationException: Operation Exception occured during oracle databaseconnection, reason: Unexpected Operation occurred.
