メインコンテンツへスキップ
SnapCenter Plug-in for Oracleの導入が失敗して、Javaとスペースのエラーが表示されます
15
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>翻訳の場合</a>
Last Updated:
環境
SnapCenter Plug-In for Oracle ( SCO )
問題
  • SCOプラグインをホストマシンにデプロイできません。自動または手動です
  • 問題 は、次の例でキャプチャされた1つ以上のエラーで自身をマニフェストできます。
2020-04-27T11:33:56.8733687-07:00 ERROR SnapManagerWeb_435 PID=[16272] TID=[58] ErrorCode (-1), ErrorMessage (The required 1 GB disk space is not available on acme.roadrunner.com to install the plug-ins. Create more disk space for '/tmp' and install path /opt)
2020-04-27T11:33:57.2170697-07:00 ERROR SnapManagerWeb_435 PID=[16272] TID=[53] Error: sudo: sorry, you must have a tty to run sudo
2020-04-27T11:33:57.3420539-07:00 ERROR SnapManagerWeb_435 PID=[16272] TID=[70] Failed to get the java path. Command result : bash: tmp/netapp/Linux_Prechecks.sh: Permission denied
2020-04-27T11:33:57.3420539-07:00 ERROR SnapManagerWeb_435 PID=[16272] TID=[53] ErrorCode (-1), ErrorMessage (Unable to check if the port 8145 is blocked by firewall on acme.roadrunner.com. Either because the command to check firewall status failed or the '/tmp/netapp/Linux_Prechecks.sh' script is not included in the '/etc/sudoers' configuration file for non-root user.)
2020-04-27T11:33:57.4514394-07:00 ERROR SnapManagerWeb_435 PID=[16272] TID=[70] ErrorCode (-1), ErrorMessage (The required Java version is not found on acme.roadrunner.com. Install 64-bit Java version 1.8 or higher.)
New to NetApp?
