メインコンテンツへスキップ
SnapCenter Plug-in for SAP HANAのインストールがホストでSCUおよびSAP HANAプラグインを有効にできない
4
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009857124</a>
Last Updated:
環境
  • SnapCenter Plug-in for SAP HANA
  • UNIX向けSnapCenterプラグイン
  • SUSE Linux Enterprise Server 15 SP4
問題
SnapCenter Plug-in for SAP HANAのインストールが次のエラーで失敗します。
SnapManagerWeb_Log:
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] WebException caught while invoking https://euaemqdb1.vms.ad.varian.com:8145/PluginService/EnablePlugin
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] WebException Encountered, Response null
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] Exception in method: InvokeXML.
System.Net.WebException: Unable to connect to the remote server ---> System.Net.Sockets.SocketException: No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145
  at SnapMgrHelper.RestAdapter.InvokeXML[TReq,TRes](TReq request, String methodType, String remoteURL, Boolean xmlSerializer, Boolean removeXMLNamespace, Boolean dataContractDeserializer, Boolean logRequest, Boolean logResponse, Boolean addContentTypeForGET) : Detailed Exception Unable to connect to the remote server. No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145 : BaseException System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] Failed to enable plugin SCU on host euaemqdb1.vms.ad.varian.com. Error: Unable to connect to the remote server. No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145
INFO  SnapManagerWeb_266495 PID=[1768] TID=[81] Retry enable plugin after 150 seconds.
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] ErrorCode (-1), ErrorMessage (Unable to connect to the remote server. No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145)
DEBUG SnapManagerWeb_266495 PID=[1768] TID=[81] Updating the job (266495) task (Enabling SCU plug-in(s) on host) status as Failed
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] Failed to enable SCU plugin(s). Error: Unable to connect to the remote server. No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145
INFO  SnapManagerWeb_266495 PID=[1768] TID=[81] Enabling plug-in: hana on host: euaemqdb1.vms.ad.varian.com
DEBUG SnapManagerWeb_266495 PID=[1768] TID=[81] Updating the job (266495) task (Enabling SnapCenter Plug-in for SAP HANA on host) status as Failed
ERROR SnapManagerWeb_266495 PID=[1768] TID=[81] Failed to enable hana plug-in. Error: Unable to connect to the remote server. No connection could be made because the target machine actively refused it xx.xx.xx.xx:8145. Check if the Plugin Service is down or not reachable. Check if correct java path is set in the path Environment variable.
New to NetApp?
