メインコンテンツへスキップ
SnapCenter は、 disk.EnableUUID が無効または欠落している場合にディスクを列挙できません
404
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
環境
  • SnapCenter サーバ( SC )すべてのバージョン
  • SnapCenter Plug-in for Windows ( SCW )すべてのバージョン
  • SnapCenter Plug-in for VMware vSphere ( SCV )すべてのバージョン
  • VMware vCenter のすべてのバージョン
問題
  • SnapCenter で次のエラーが発生してディスクを列挙できません:
Unable to get storage details for VMDK.
UUID is not set for VMDK, check if disk.EnableUUID is set for the virtual machine
  • またはでエラーが検出SMCore_<JobID>.logされる場合があります SnapManagerWeb.log
例 1 :
ERROR SMCore_336 PID=[6552] TID=[32] Unable to get storage details for VMDK.
ERROR SMCore_336 PID=[6552] TID=[32] ErrorCode (-1), ErrorMessage (Unable to get storage details for VMDK.
UUID is not set for VMDK, check if disk.EnableUUID is set for the virtual machine)
DEBUG SMCore_336 PID=[6552] TID=[32] DiscoverVirtualResources - Exit
DEBUG SMCore_336 PID=[6552] TID=[32] UpdateStorageFootprint - Enter
ERROR SMCore_336 PID=[6552] TID=[32] Invalid response object
例 2 :
DEBUG SnapManagerWeb_486725 PID=[13496] TID=[86] Response Data: ****************************
_message Storage discovery failed, received error during operation: java.lang.ArrayIndexOutOfBoundsException.
Please refer to operation logs for more details.
WARN SnapManagerWeb_486725 PID=[13496] TID=[100] Storage file system <MountPoint> is NOT associated with Windows filesystem resource.
例 3 :
Verbose SDW PID=[2168] TID=[2604] INFO: StorageSystem manager does not have any registered storage system connections!
Verbose SDW PID=[2168] TID=[2604] ++CifsServerCache::Initialize
Verbose SDW PID=[2168] TID=[2604] No vserver is passed in.
例 4 :
DEBUG SnapManagerWeb_486726 PID=[13496] TID=[47] Getting nsm object for resource <VMDK_MountPoint_Folder>
INFO SnapManagerWeb_486726 PID=[13496] TID=[47] StorageFileSystem count: 0
DEBUG SnapManagerWeb_486726 PID=[13496] TID=[47] Could not find resource's StorageFileSystem.
  • マウントされたディスクはオフラインThe disk is offline because it has a signature collision with another disk that is onlineになり、メッセージ "" が表示されます。
New to NetApp?
