メインコンテンツへスキップ
クローンライフサイクルジョブが「Failed to mount storage resource、error is Failed to create the volume clone」というメッセージで失敗します。
17
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>2009989383</a>
Last Updated:
環境
  • SnapCenterサーバ[SC]
  • SnapCenter Plug-in for SQL [SCSQL]
  • Data ONTAP 9.14.1以前のバージョン。
問題
  • SCSQLクローンがSnapCenterでランダムに失敗し、次のエラーが表示されます。
Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.'
  • SMCoreログ:
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Internal Error. Failed to lookup Snapshot copy tags for "<Snapshot_Name>". Error: Bad Snapshot name.
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] No retry condition match found or max retry reached. Throwing error The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Internal Error. Failed to lookup Snapshot copy tags for "<Snapshot_Name>". Error: Bad Snapshot name.
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] --PSHelper::RunCommand
2024-03-29T04:30:51.8943418-05:00 ERROR SMCore_103293 PID=[3676] TID=[36] Failed to create volume clone
New to NetApp?
