メインコンテンツまでスキップ
SnapCenter ディスクリソースの検出が完了しません
55
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
に適用されます
SnapCenter 4.1.1
SnapCenter プラグイン for Windows
問題
検出の実行中に、 SnapCenter のログにこのエラーが記録されます。
 2020-04-27T07:43:28.5447182-04:00 ERROR SnapManagerWeb_73201 PID=[4952] TID=[36] Exception in method: InvokeXML. System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count) at System.Net.Security._SslStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security._SslStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security._SslStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.TlsStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead) --- End of inner exception stack trace --- at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) at System.Net.WebClient.UploadString(Uri address, String method, String data) at SnapMgrHelper.RestAdapter.InvokeXML[TReq,TRes](TReq request, String methodType, String remoteURL, Boolean xmlSerializer, Boolean removeXMLNamespace, Boolean dataContractDeserializer, Boolean logRequest, Boolean logResponse) : Detailed Exception The underlying connection was closed: An unexpected error occurred on a receive. Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. An existing connection was forcibly closed by the remote host : BaseException System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) 2020-04-27T07:43:28.5457178-04:00 ERROR SnapManagerWeb_73201 PID=[4952] TID=[36] Exception in method: DiscoverHostResourcesInternal. System.Net.WebException: The underlying connection was closed: An unexpected error occurred on a receive. ---> System.IO.IOException: Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. ---> System.Net.Sockets.SocketException: An existing connection was forcibly closed by the remote host at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) --- End of inner exception stack trace --- at System.Net.Sockets.NetworkStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.FixedSizeReader.ReadPacket(Byte[] buffer, Int32 offset, Int32 count) at System.Net.Security._SslStream.StartFrameHeader(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security._SslStream.StartReading(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.Security._SslStream.ProcessRead(Byte[] buffer, Int32 offset, Int32 count, AsyncProtocolRequest asyncRequest) at System.Net.TlsStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.PooledStream.Read(Byte[] buffer, Int32 offset, Int32 size) at System.Net.Connection.SyncRead(HttpWebRequest request, Boolean userRetrievedStream, Boolean probeRead) --- End of inner exception stack trace --- at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request) at System.Net.WebClient.UploadString(Uri address, String method, String data) at SnapMgrHelper.RestAdapter.InvokeXML[TReq,TRes](TReq request, String methodType, String remoteURL, Boolean xmlSerializer, Boolean removeXMLNamespace, Boolean dataContractDeserializer, Boolean logRequest, Boolean logResponse) at SnapManager.SMSCore.Discovery.DiscoveryBizHelper.DiscoverHostResourcesInternal(SmDiscoverResourcesRequest request) : Detailed Exception The underlying connection was closed: An unexpected error occurred on a receive. Unable to read data from the transport connection: An existing connection was forcibly closed by the remote host. An existing connection was forcibly closed by the remote host : BaseException System.Net.Sockets.SocketException (0x80004005): An existing connection was forcibly closed by the remote host
New to NetApp?
