メインコンテンツへスキップ
AFF-A250の1つのノードで、パートナーPSUのシャーシの電源が低下したことが報告されます
154
Visibility:
Votes:
1
Category:
fas-systems<a>2009278627</a>
Specialty:
hw
Last Updated:
環境
  • AFF-A250
  • FAS500f
問題
  • AFF-A250の1つのノードで CHASSIS POWER SUPPLY DEGRADED 、パートナーPSUのアラートが報告されます。たとえば、コントローラBがPSU1 Degradeと報告するか、コントローラAがPSU2 Degradeと報告します。
  • ノードのPSUセンサーで問題 を使用して読み取り不能になっていますが、パートナーでは読み取り不能です。例:
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Inlet is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Hot is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 FB Hot is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 In Fault is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Warning is Unreadable
[?] Mon Aug 22 20:08:07 +0800 [Node-02: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Out Fault is Unreadable
[?] Mon Aug 22 20:08:09 +0800 [Node-02: power_low_monitor: monitor.chassisPower.degraded:alert]: Chassis power is degraded: Power Supply Status Critical: PSU1.
[?] Mon Aug 22 20:08:09 +0800 [Node-02: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1.
New to NetApp?
  • この記事は役に立ちましたか?
