メインコンテンツへスキップ
AFF A320は、nvmem .battery .wrongChargeの実行後にシャットダウンします
1
Visibility:
Internal
Votes:
0
Category:
not set
Specialty:
not set
Last Updated:
環境
  • AFF A320
  • ONTAP 9
問題
のあとにノードがシャットダウンする nvmem.battery.wrongCharge:alert
  • クラスタ内の1つのノードに対するEMSメッセージ:
Sat Dec 19 16:23:27 +0100 [CLUSTERBA-CTRLA: env_mgr: callhome.battery.warning:alert]: Call home for BATTERY (wrong charge) WARNING.
... (repeated hourly)
Sun Dec 20 15:23:38 +0100 [CLUSTERBA-CTRLA: env_mgr: nvmem.battery.wrongCharge:alert]: The NVMEM battery charger is charging the battery even though the battery is not requesting to be charged. To prevent data loss, the system will shut down in 60 minutes.
Sun Dec 20 15:24:18 +0100 [CLUSTERBA-CTRLA: env_mgr: callhome.battery.warning:alert]: Call home for BATTERY (wrong charge) WARNING.
Sun Dec 20 16:22:30 +0100 [CLUSTERBA-CTRLA: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery charging current failed)
Battery Charge Failed?       discrete fault   normal TRUE
Battery Capacity Message     discrete failed  failed
Bat Curr                   current  normal  -40 mA
Bat Charging State          discrete fault   normal WRONG_CHARGE
Jan  7 14:17:14 (none) env_mgr[1035]: Payload EMS: EMS_nvmem_battery_wrongCharge(in 24 hours)
Jan  7 14:17:46 (none) env_mgr[1035]: Payload EMS: EMS_callhome_battery_warning(BATTERY (wrong charge))
Jan  7 15:17:20 (none) env_mgr[1035]: Payload EMS: EMS_nvmem_battery_wrongCharge(in 23 hours)
Jan  7 15:17:47 (none) env_mgr[1035]: Payload EMS: EMS_callhome_battery_warning(BATTERY (wrong charge))
  • カウンタが24時間に達すると、ノードがシャットダウンします
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
  • この記事は役に立ちましたか?
