メインコンテンツへスキップ
AFF A400/FAS8300/FAS8700がnvmem.battery.noChargeアラートでシャットダウンする
2,941
Visibility:
Votes:
1
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF A400
  • AFF C400
  • ASA A400
  • ASA C400
  • FAS8300
  • FAS8700
問題
  • 予期しないノードのシャットダウン
コンソールログ
  • 起動時のコンソールメッセージ:
 WARNING:  The battery is experiencing a critical failure:
    - Battery is not present
   Without a working battery, the system cannot retain data
   during a power outage, which can result in data loss.
   Power down the system and verify that the battery is
   properly installed.
   To ignore this failure and boot the system in a mode
   where data loss might occur, press 'c' followed by 'Enter'
EMSログ
  • いずれかのエラーがノードのシャットダウン前に報告されます。例:
    • NVMEMバッテリの充電が要求されています
[node_name: env_mgr: nvmem.battery.noCharge:alert]: The NVMEM battery is requesting to be charged but the charger is not charging the battery. To prevent data loss, the system will shut down in 20 minutes.
[node_name: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (no charge) CRITICAL.
[node_name: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery not charging)
[node_name: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery charging current failed)
<callhome_battery_failure_1
     subject="BATTERY (current high)"/>
<monitor_shutdown_emergency_1
     reason="Environmental Reason Shutdown (Battery current critical)"
  • NVMEMバッテリが存在しません
[node_name:callhome.battery. failure: EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
[node_name: env_mgr: nvmem.battery.notPresent:alert]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • NVRAMバッテリ残量が危険なほど低下しています
[node_name: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
  • NVRAMバッテリー容量が少ない
[node_name: env_mgr: nvmem.battery.capLow:alert]: The NVMEM battery capacity is low (2 cycles).
  • 次のAutoSupport件名のメッセージが報告されます:
HA Group Notification from node_name (BATTERY (no charge)) EMERGENCY or
HA Group Notification (BATTERY (no charge)) EMERGENCY
  • パートナーがテイクオーバーを実行します:
[node_name: cf_main: cf.fsm.firmwareStatus:info]: Failover monitor: partner Halted
[node_name: cf_main: cf.fsm.takeover.on.halt:info]: Failover monitor: Node initiated automatic takeover after detecting that its partner node has halted.
問題を確認するには、次のいずれかの方法を使用します:
BMCプロンプト
  1. 次のコマンドを実行します。
BMC node_name>system battery show
  1. 結果で以下を確認します:
    1. Current フィールドに 「0 mA」が表示されます。
    2. RelativeCharge フィールドに 71%以下が表示されている。
    3. ChargingCurrentフィールドに「1000 mA」が表示されている。
AutoSupportログ
  1. AutoSupportというタイトルの「BATTERY (no charge)」を開きます。
  2. SP-LATEST-STATISTICSセクションに移動します。
  3. 出力で、以下を確認します:
    1. Log Collection Timeに現在の日付が表示されている(現在の日付/時刻が表示されない場合は、AutoSupportセクションSP-LATEST-STATISTICSを使用して確認しないでください)。
    2. Current フィールドに 「0 mA」が表示されている。
    3. RelativeCharge フィールドに 71%以下が表示されている。
    4. ChargingCurrentフィールドに「1000 mA」が表示されている。
  4. PLATFORM-SENSORS.XMLセクションに移動します。
  5. 出力で、以下のいずれか1つ以上が failed または faultとして表示されていることを確認します:
    1. DBlade Battery Voltage
    2. Battery Charge Failed?
    3. Battery Charge
    4. Bat Charging State
New to NetApp?
