メインコンテンツへスキップ
PCI カードの追加 / 交換後もオレンジの LED が点灯
1
Visibility:
Internal
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
に適用されます
  • FAS8040
問題
  • FAS8040 に PCI カードを追加または交換したあとも、ノードの LED は黄色に点灯しますが、アラートは表示されません。
  • ::*> system controller fru led show「」または「SP> system fru led show all」をチェックすると、 LED が点灯していないことがわかります。
Node                  FRU Type    Bay Slot State   Lit By
vmstor3
                      controller  A   1    off     -
                      pci         -   1    off     -
                      pci         -   2    off     -
                      pci         -   3    off     -
                      pci         -   4    off     -
                      batt-nv     -   1    off     -
                      boot        -   1    off     -
                      dimm-nv     -   1    off     -
                      dimm        -   1    off     -
                      dimm        -   2    off     -
                      dimm        -   3    off     -
                      dimm        -   4    off     -
vmstor4
                      controller  B   1    off     -
                      pci         -   1    off     -
                      pci         -   2    off     -
                      pci         -   3    off     -
                      pci         -   4    off     -
                      batt-nv     -   1    off     -
                      boot        -   1    off     -
                      dimm-nv     -   1    off     -
                      dimm        -   1    off     -
                      dimm        -   2    off     -
                      dimm        -   3    off     -
                      dimm        -   4    off     -
24 entries were displayed.
  • SP ログに「 PCI_SW_Riser_Err 」と表示される
「 P-latest-IPMI 」
PCI_SW0_Err      | 0x0        | discrete   | Deasserted | na        | na        | na        | na
PCI_SW1_Err      | 0x0        | discrete   | Deasserted | na        | na        | na        | na
PCI_SW_Riser_Err | 0x0        | discrete   | Asserted  | na        | na        | na        | na
「 P-latest-system-event-log 」
Record 2088: Thu Jan 01 00:00:56.296944 1970 [IPMI.notice]: e101 | 02 | EVT: 0300ffff | Fan_Override | Assertion Event, "State Deasserted"
Record 2089: Thu Jan 01 00:00:56.675375 1970 [IPMI.notice]: e201 | 02 | EVT: 0301ffff | Bat_Tca_Status | Assertion Event, "State Asserted"
Record 2090: Thu Jan 01 00:00:57.364629 1970 [IPMI.notice]: e301 | 02 | EVT: 6f01ffff | Partner_IO_Pre | Assertion Event, "Absent"
Record 2091: Thu Jan 01 00:00:57.859289 1970 [IPMI.notice]: e401 | 02 | EVT: 0301ffff | PCI_SW_Riser_Err | Assertion Event, "State Asserted"
Record 2092: Thu Jan 01 00:00:57.882961 1970 [IPMI.notice]: e501 | 02 | EVT: 0901ffff | Wrench_Port_Up | Assertion Event, "Device Enabled"
Record 2093: Thu Jan 01 00:00:57.906988 1970 [IPMI.notice]: e601 | 02 | EVT: 0900ffff | LkWrench_Port_Up | Assertion Event, "Device Disabled"
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
