メインコンテンツへスキップ
バッテリ残量低下 SP HBT MISSED
153
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • ONTAP 9
  • サービス プロセッサ(SP)
問題
  • EMSレポートBATTERY_LOW.
[node: statd: monitor.nvramLowBattery:critical]: NVRAM battery is dangerously low.
[node: statd: monitor.nvramLowBattery.notice:info]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[node: statd: callhome.battery.low:error]: Call home for BATTERY_LOW
[node: statd: monitor.shutdown.nvramLowBattery.pending:warning]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
  • SP-LATEST-IPMI バッテリーは正常です。
Bat_1.5V         | 1.494      | Volts      | ok         | 1.280     | 1.348     | 1.649     | 1.727
Bat_3.0V         | 3.146      | Volts      | ok         | 2.545     | 2.703     | 3.504     | 3.575
Bat_8.0V         | 7.800      | Volts      | ok         | 6.000     | 6.600     | 8.600     | 8.700
Bat_Curr         | 0.000      | Amps       | ok         | na        | na        | 0.800     | 0.900
Bat_Capacity     | 1.792      | Amps * hour | ok         | na        | na        | na        | na
Bat_Run_Time     | 114.000    | hour       | ok         | 76.000    | 78.000    | na        | na
Bat_Temp         | 25.000     | degrees C  | ok         | 0.000     | 10.000    | 55.000    | 64.000
Charger_Curr     | 0.000      | Amps       | ok         | na        | na        | 2.200     | 2.300
Charger_Cycles   | 35.000     | cycles     | ok         | na        | na        | 250.000   | 251.000
Charger_Volt     | 8.200      | Volts      | ok         | na        | na        | 8.600     | 8.700
  • EMSレポートSP HBT MISSEDはBATTERY_LOW後に作成されます。
[node: spsm_listener: sp.heartbeat.stopped:warning]: Have not received a IPMI heartbeat from the Service Processor (SP) in last 20 seconds.
[node: spsm_listener: callhome.sp.hbt.missed:notice]: Call home for SP HBT MISSED
New to NetApp?
  • この記事は役に立ちましたか?
