メインコンテンツへスキップ
CPU_Temp_Margin "State Asserted" および "State Deasserted" が繰り返し報告される
45
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
HW
Last Updated:
環境
FAS2720
問題
  • CPU_Temp_Margin "State Asserted" および "State Deasserted" が BMC ログから繰り返し報告されます:
Record 1223: Wed Nov 29 17:01:11.633898 2023 [IPMI.notice]: 02c6 | 02 | EVT: 0157f5f5 | CPU_Temp_Margin | Assertion Event, "Upper Non-critical going high" | Reading: -11.000 | Threshold: -11.000
Record 1224: Wed Nov 29 17:01:43.663299 2023 [IPMI.notice]: 02c7 | 02 | EVT: 8157f4f5 | CPU_Temp_Margin | Deassertion Event, "Upper Non-critical going high" | Reading: -12.000 | Threshold: -11.000
Record 1225: Wed Nov 29 17:02:19.710624 2023 [IPMI.notice]: 02c8 | 02 | EVT: 0157f5f5 | CPU_Temp_Margin | Assertion Event, "Upper Non-critical going high" | Reading: -11.000 | Threshold: -11.000
Record 1226: Wed Nov 29 17:02:45.734418 2023 [IPMI.notice]: 02c9 | 02 | EVT: 8157f4f5 | CPU_Temp_Margin | Deassertion Event, "Upper Non-critical going high" | Reading: -12.000 | Threshold: -11.000
  • CHASSIS OVER TEMPERATUREがEMSログから繰り返し報告されています:
Thu Nov 30 02:01:11 +0900 [node_name: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: CPU Temp Margin is warning high (-11 C).
Thu Nov 30 02:01:51 +0900 [node_name: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Thu Nov 30 02:02:11 +0900 [node_name: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
New to NetApp?
  • この記事は役に立ちましたか?
