メインコンテンツへスキップ
CPU VRD温度センサー読み取り値AFF-A900およびFAS9500
22
Visibility:
Votes:
0
Category:
aff-series<a>2009337602</a>
Specialty:
hw
Last Updated:
環境
  • AFF-A900
  • FAS9500
  • ONTAP 9
問題
  • CPU1またはCPU2 VRD温度センサーがONTAPによって誤って読み取られ、0度と報告され、シャーシの低温警告がトリガーされます。
    • EMSログ:
      • Wed Oct 19 01:48:30 -0400 [Node_Name: env_mgr: monitor.chassisTemperature.cool:alert]: Chassis temperature is too cool: CPU2 VRD Temp is critical low (0 C).
    • BMCシステムイベントログ:
Record 1527: Sat Mar 04 00:32:01.076611 2023 [IPMI.notice]: 0513 | 02 | EVT: 01500005 | CPU2_VRD_Temp | Assertion Event, "Lower Non-critical going low " | Reading: 0.000 | Threshold: 5.000
Record 1528: Sat Mar 04 00:32:01.078001 2023 [IPMI.notice]: 0514 | 02 | EVT: 01520000 | CPU2_VRD_Temp | Assertion Event, "Lower Critical going low " | Reading: 0.000 | Threshold: 0.000
Record 1963: Mon Apr 24 18:13:18.996830 2023 [IPMI.notice]: 06b9 | 02 | EVT: 01500005 | CPU1_VRD_Temp | Assertion Event, "Lower Non-critical going low " | Reading: 0.000 | Threshold: 5.000
Record 1964: Mon Apr 24 18:13:18.998197 2023 [IPMI.notice]: 06ba | 02 | EVT: 01520000 | CPU1_VRD_Temp | Assertion Event, "Lower Critical going low " | Reading: 0.000 | Threshold: 0.000
Record 1978: Wed Apr 26 11:38:01.061589 2023 [IPMI.notice]: 06c7 | 02 | EVT: 6f02ffff | PSU1_Status | Assertion Event, "Fault"
Record 1979: Wed Apr 26 11:38:01.139064 2023 [IPMI.notice]: 06c8 | 02 | EVT: 6f02ffff | PSU3_Status | Assertion Event, "Fault"
Record 1980: Wed Apr 26 11:38:05.910595 2023 [IPMI.notice]: 06c9 | 02 | EVT: 6f02ffff | Fan3_Status | Assertion Event, "Fault"
  • アラートは秒後にクリアされます。
    • EMSログ:
      • Wed Oct 19 01:48:31 -0400 [Node_Name: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
    • BMCシステムイベントログ:
Record 1981: Wed Apr 26 11:38:05.973490 2023 [IPMI.notice]: 06ca | 02 | EVT: ef02ffff | PSU1_Status | Deassertion Event, "Fault"
Record 1982: Wed Apr 26 11:38:06.058606 2023 [IPMI.notice]: 06cb | 02 | EVT: ef02ffff | PSU3_Status | Deassertion Event, "Fault"
Record 1983: Wed Apr 26 11:38:09.932151 2023 [IPMI.notice]: 06cc | 02 | EVT: ef02ffff | Fan3_Status | Deassertion Event, "Fault"
  • 他のセンサー(PSU、ファン、PCM)が引き続き「障害」をアサートおよびディアサートし、システムファンの速度が高レベルと非クリティカルレベルの間で変動する可能性があります。
Record 1938: Fri Apr 21 04:10:21.983012 2023 [IPMI.notice]: 06a0 | 02 | EVT: 81598aff | Fan1_Speed1 | Deassertion Event, "Upper Critical going high" | Reading: 8280.000 | Threshold: 15300.000
Record 1939: Fri Apr 21 04:10:21.987010 2023 [IPMI.notice]: 06a1 | 02 | EVT: 81578ad9 | Fan1_Speed1 | Deassertion Event, "Upper Non-critical going high" | Reading: 8280.000 | Threshold: 13020.000
Record 1940: Fri Apr 21 04:10:21.989607 2023 [IPMI.notice]: 06a2 | 02 | EVT: 81598bff | Fan1_Speed2 | Deassertion Event, "Upper Critical going high" | Reading: 8340.000 | Threshold: 15300.000
Record 1941: Fri Apr 21 04:10:21.991062 2023 [IPMI.notice]: 06a3 | 02 | EVT: 81578bd9 | Fan1_Speed2 | Deassertion Event, "Upper Non-critical going high" | Reading: 8340.000 | Threshold: 13020.000
Record 1942: Fri Apr 21 04:10:22.001742 2023 [IPMI.notice]: 06a4 | 02 | EVT: 81598aff | Fan1_Speed3 | Deassertion Event, "Upper Critical going high" | Reading: 8280.000 | Threshold: 15300.000
Record 1943: Fri Apr 21 04:10:22.003202 2023 [IPMI.notice]: 06a5 | 02 | EVT: 81578ad9 | Fan1_Speed3 | Deassertion Event, "Upper Non-critical going high" | Reading: 8280.000 | Threshold: 13020.000
Record 1944: Fri Apr 21 04:10:22.004990 2023 [IPMI.notice]: 06a6 | 02 | EVT: 81598aff | Fan1_Speed4 | Deassertion Event, "Upper Critical going high" | Reading: 8280.000 | Threshold: 15300.000
Record 1945: Fri Apr 21 04:10:22.006297 2023 [IPMI.notice]: 06a7 | 02 | EVT: 81578ad9 | Fan1_Speed4 | Deassertion Event, "Upper Non-critical going high" | Reading: 8280.000 | Threshold: 13020.000
New to NetApp?
  • この記事は役に立ちましたか?
