メインコンテンツへスキップ
BATTERY(not present)CRITICAL FAS27xxおよびAFF A220のコールホーム
65
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF A220
  • AFF C190
  • FAS2750
  • FAS2720
問題
  • 起動時のエラー報告:
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter
  • リブートの直前にEMSで次のエラーが表示されました
Mar 24 06:49:59 [node:callhome.battery.failure:EMERGENCY]: Call home for BATTERY (not present) CRITICAL.
Mar 24 06:51:00 [node:nvmem.battery.notPresent:ALERT]: The NVMEM battery is not present. To prevent data loss, the system will shut down in 5 minutes.
  • BMCから"system battery show"を実行すると、バッテリがないと報告される
BMC-01> system battery show
Battery pack is absent.
  • システムがバッテリパックを認識できません:
::> system node environment sensors show
Bat_Temp      | na     | degrees C  | na      | 0.000    | 5.000    | 56.000   | 60.000
Bat_Volt      | na     | Volts    | na      | 5.500    | 5.600    | 8.500    | 8.600
Bat_Curr      | na     | Amps     | na      | na     | na     | 1.520    | 1.800
Bat_Rem_Cap    | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Full_Cap    | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Charge_Curr  | na     | Amps     | na      | na     | na     | 2.400    | 2.900
Bat_Charge_Volt  | na     | Volts    | na      | na     | na     | 8.900    | 9.000
Bat_Design_Cap   | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Initial_Fcc  | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Average_Temp | na     | degrees C  | na      | na     | na     | na     | na
Bat_Rem_Cap_off  | na     | Amps * hour | na      | na     | na     | na     | na
Bat_Dstg_Cycles  | na     | cycles    | na      | 2.000    | 5.000    | na     | na
Bat_Power_Fault  | 0x0     | discrete   | Asserted   | na     | na     | na     | na
Bat_Dsg_FET_Flt  | na     | discrete   | na      | na     | na     | na     | na
Bat_Chg_FET_Flt  | na     | discrete   | na      | na     | na     | na     | na
Bat_Pack_Invalid | na     | discrete   | na      | na     | na     | na     | na
Bat_Cycle_Cnt   | na     | cycles    | na      | na     | na     | na     | na
Bat_Lrn_Active   | na     | discrete   | na      | na     | na     | na     | na
  • BMCを最新バージョンにアップグレードし、センサー出力を再確認してください。
New to NetApp?
