メインコンテンツへスキップ
シャーシの電力が低下している:P1.2Vスタンバイがクリティカル低(0mV)
83
Visibility:
Votes:
0
Category:
fas-systems<a>2008773034</a><a>(翻訳用</a>
Specialty:
hw
Last Updated:
環境
  • FAS2720
  • ベースボード管理コントローラ
問題
  • 毎時のEMSアラート:
例:
Time Node Severity Event
5/20/2021 23:14:59 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 22:14:58 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 21:14:58 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 20:14:57 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 19:14:56 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 18:14:55 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 17:14:54 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
5/20/2021 16:14:53 node-01 ALERT monitor.chassisPower.degraded: Chassis power is degraded: P1.2V Standby is critical low (0 mV).
  • プラットフォームセンサー出力:
例:
Node Sensor          State Value/Units Crit-Low Warn-Low Warn-Hi Crit-Hi
node-01
   PVCCIN CPU       normal
                   1785 mV    1249    1501   1900   2005
   P5V STBY        normal
                   4966 mV    4264    4368   5694   5824
   P5V           normal
                   5070 mV    4264    4368   5694   5824
   PVDDQ DDR4 AB      normal
                   1221 mV    1086    1100   1299   1320
   P1.2V Standby
             crit-low
                     0 mV    1086    1100   1299   1398
  • 問題 はBMCのリブート後も維持されます。
New to NetApp?
  • この記事は役に立ちましたか?
