シャーシの電力が低下しています。PVTT DDR4 ABはクリティカルハイ(660 mV)です。
環境
- FAS2720
- FAS2750
問題
FAS2720/FAS2750 ではシャーシ電源アラートが多数表示されます。
EMS
ログ:Wed May 03 01:03:39 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 02:03:41 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 03:03:42 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 03:31:32 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 04:31:33 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 05:31:34 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 06:31:35 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 07:31:36 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 08:31:36 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 09:31:38 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 10:31:39 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
Wed May 03 10:54:39 +0800 [Node-02: env_mgr: monitor.chassisPower.degraded:alert]: Chassis power is degraded: PVTT DDR4 AB is critical high (660 mV).
