メインコンテンツへスキップ
HA ペアで読み取り不能な AFF-A800 のシャーシ温度センサー
70
Visibility:
Votes:
0
Category:
aff-series<a>2008620609.</a>
Specialty:
hw
Last Updated:
環境
  • AFF-A800
問題
  • AFF-A800 では、 HA ペアの環境シャットダウンを求める前にシャーシの温度が高すぎることが表示されます
  • 次の故障したセンサー読み取り値が表示される可能性があります。
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp1) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp2) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp2) is not readable.
Wed Jan 20 23:22:51 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp3) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp3) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM LTemp4) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserM RTemp4) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (RiserR LTemp1) is not readable.
Wed Jan 20 23:22:52 -0300 [node: env_mgr: monitor.temp.unreadable:error]: The controller temperature (LED Board Temp2) is not readable.
  • イベントログに表示されるイベントを次に示します。
[NACA800-01: monitor: monitor.globalStatus.critical:EMERGENCY]: Chassis temperature is too high..
[NACA800-01: env_mgr: callhome.chassis.overtemp:EMERGENCY]: Call home for CHASSIS OVER TEMPERATURE SHUTDOWN
[NACA800-01: env_mgr: callhome.chassis.hitemp:error]: Call home for CHASSIS OVER TEMPERATURE
New to NetApp?
