メインコンテンツへスキップ
ディスク シェルフの電源装置で冷却ファンのエラーが検出されました
225
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
すべてのディスク シェルフ
問題
  • PSU警告LEDはアンバーです。
  • システムでAutoSupport(ASUP)アラートが生成され、エラー SHELF COOLING UNIT FAILEDが表示されました
    EMS
    [node-01:dsa_worker1:ses.status.fanWarning:notice]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b cooling fan warning for Cooling element 1: not installed. This module is on the rear of the shelf on the lower left power supply.
    [node-01:dsa_worker1:callhome.shlf.fan.warn:error]: Callhome for SHELF COOLING UNIT FAILED
    [node-01:dsa_worker1:ses.status.fanWarning:notice]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b cooling fan warning for Cooling element 2: not installed.
    [node-01:dsa_worker1:ses.status.temperatureWarning:alert]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b temperature warning for Temperature sensor 6: not installed.
    [node-01:dsa_worker1:ses.status.temperatureWarning:alert]: DS224-12 (S/N xxxxxxxxxxxx) shelf 24 on channel 0b temperature warning for Temperature sensor 7: not installed.
    Additional sysconfig output indicated:
    環境
    Cooling Units by element:
    [1] Unavailable
    [2] Unavailable
    Shelf temperatures by element:
    [6] Unavailable
    [7] Unavailable
    Temperature thresholds by element:
    [6] High critical: Unavailable; high warning: Unavailable
    Low critical:  Unavailable; low warning:  Unavailable
    [7] High critical: Unavailable; high warning: Unavailable
  • storage shelf show -instance コマンドに次のエラーが表示されます。
::> storage shelf show -shelf-id 24 -instance
      Shelf Name: 4.24
       Stack ID: 4
       Shelf ID: 24
       Shelf UID: 50:0a:09:80:08:40:50:40
     Serial Number: SHJSGxxxxxxxxxx
      Module Type: IOM6
         Model: DS4246
     Shelf Vendor: NETAPP
      Disk Count: 24
    Connection Type: SAS
      Shelf State: Online
        Status: Critical
Fan "2" is running below normal RPM threshold. Fan is located in the rear of the shelf on the upper left power supply.
New to NetApp?
