FAS2554フラッピングシャーシ温度の警告
環境
問題
- 「フラッピング」状態のシャーシ温度警告が連続して表示されます例:
Thu May 05 18:16:14 0200 [node_name-01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Out Flow Temp is warning high (82 C).
Wed May 11 04:59:56 0200 [node_name-01: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Wed May 11 08:00:39 0200 [node_name-01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Out Flow Temp is warning high (82 C).
Wed May 11 08:04:19 0200 [node_name-01: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Thu May 12 00:04:41 0200 [node_name-01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Out Flow Temp is warning high (82 C).
Thu May 12 00:06:21 0200 [node_name-01: env_mgr: monitor.chassisTemperature.ok:notice]: Chassis temperature is ok.
Thu May 12 03:43:53 0200 [node_name-01: env_mgr: monitor.chassisTemperature.warm:alert]: Chassis temperature is too warm: Out Flow Temp is warning high (82 C).
- 両方のノードの環境で正常な温度が報告されています:
node_name-01
Sensor Name | Current | Unit | Status | LCR | LNC | UNC | UCR
CPU0_Temp_Margin | -22.000 | degrees C | ok | na | na | -5.000 | 0.000
In_Flow_Temp | 47.000 | degrees C | ok | 0.000 | 10.000 | 70.000 | 75.000
Out_Flow_Temp | 79.000 | degrees C | ok | 0.000 | 10.000 | 82.000 | 87.000
node_name-02
CPU0_Temp_Margin | -34.000 | degrees C | ok | na | na | -5.000 | 0.000
In_Flow_Temp | 42.000 | degrees C | ok | 0.000 | 10.000 | 70.000 | 75.000
Out_Flow_Temp | 70.000 | degrees C | ok | 0.000 | 10.000 | 82.000 | 87.000
- データセンター内のエアフローを正しく調整し、他の温度問題 がないことを確認します
- サービスプロセッサファームウェアが最新バージョンに更新されました
