メインコンテンツまでスキップ
FAS8300 / FAS8700 / A400マザーボードの交換用0ディスクが見つかりませんルートボリュームが見つかりません
35
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw<a>2009889586</a>
Last Updated:
環境
問題
    マザーボードの交換時:
    • ノードが「Waiting for giveback...」ステータスでブートしていません
    • ディスクの自動再割り当てが失敗し、新しいマザーボードがブートループに入る:
Dec 30 10:44:24 [CLUSTER-02:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
Dec 30 10:44:24 [CLUSTER-02:raid.assim.tree.noRootVol:error]: No usable root volume was found!
WARNING: 0 disks found!
Storage Adapters found:
0 Fibre Channel Storage Adapters found!
8 SAS Adapters found!
0 Parallel SCSI Storage Adapters found!
0 ATA Adapters found!
Select option 4 from the boot menu to choose disks for the root volume and spare core space.
Target Adapters found:
4 Fibre Channel Target Adapters found!
0 iSCSI Target Adapters found!
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
New to NetApp?
