メインコンテンツへスキップ
FAS9000のEMSエラーは、環境シャットダウン後およびシャーシファンの交換後に発生します
253
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
環境
  • FAS9000
  • ONTAP
問題
ファンで障害が発生して環境がシャットダウンされると、交換してもEMSメッセージに表示され、ファンでフィールド交換可能ユニット障害が続けられたことが示されます。
cluster::*> event show -node local -event *fan*|*psu*
Time         Node        Severity    Event
10/25/2017 12:00:00 cluster
                   ALERT      monitor.fan.failed: Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1. <<<<<<<<<<<<<<<<< Generated when PSU 3 cable removed and inserted back after some time .
10/25/2017 11:52:00 cluster
                   EMERGENCY    monitor.globalStatus.critical: Controller failover of nbs-plat-9000-122 is not possible: Controller Failover takeover disabled. Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1.
10/25/2017 11:37:00 cluster
                   EMERGENCY    monitor.globalStatus.critical: Controller failover of nbs-plat-9000-122 is not possible: Controller Failover takeover disabled. Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1. Power Supply Status Critical: PSU3.
10/25/2017 11:09:00 cluster
10/25/2017 11:00:00 cluster
                   EMERGENCY    monitor.globalStatus.critical: Controller failover of nbs-plat-9000-122 is not possible: Controller Failover takeover disabled. Multiple fans has failed: FanA2 F4, FanA2 F3, FanA2 F2, FanA2 F1. Power Supply Status Critical: PSU1.
New to NetApp?
