メインコンテンツまでスキップ
IOM のオレンジの LED が点灯
37
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
DS2246
問題
  • IOM モジュールの黄色の LED
  • PHY が Rate Unknow を報告 SAS-EXPANDER-PHY-STATE
例:
Expander phy state on 4b.4 (NETAPP  :DS224IOM6     SHFFG1513000064):
                Pwr      Invald Disprt Loss   Phy   CRC   Phy
              Pwr Ccl Rsv Rls DWord  Error  Sync   Reset  Error  Change SATA
PHY/BAY STATE        ON  Cnt Cnt Cnt Count  Count  Count  Prob   Cnt   Cnt   Affiliation
 0/P0:0 Rate unknown
 1/P0:1 Rate unknown
 2/P0:2 Rate unknown
 3/P0:3 Rate unknown
 4/P1:0 6.0 Gb/s      --- --- --- --- 0    0    0    0    0    3    ----------------
 5/P1:1 6.0 Gb/s      --- --- --- --- 0    0    0    0    0    3    ----------------
 6/P1:2 6.0 Gb/s      --- --- --- --- 0    0    0    0    0    3    ----------------
 7/P1:3 6.0 Gb/s      --- --- --- --- 0    0    0    0    0    3    ----------------
  • IOM B で問題が発生しました sysconfig -a
例:
   slot 0: SAS Host Adapter 0a (PMC-Sierra PM8001 rev. C, SAS, <UP>)
      Firmware rev:     01.11.07.00
      Base WWN:       5:00a098:00376dd:70
      Phy State:      [0] Enabled, 6.0 Gb/s
                [1] Enabled, 6.0 Gb/s
                [2] Enabled, 6.0 Gb/s
                [3] Enabled, 6.0 Gb/s
      QSFP Vendor:     Amphenol
      QSFP Part Number:   112-00256+A0
      QSFP Type:      Passive Copper 0.5m ID:00
      QSFP Serial Number: APF15112566N9G
      Shelf 0: DS2246  Firmware rev. IOM6 A: 0173  IOM6 B: 0173
      Shelf 1: DS2246  Firmware rev. IOM6 A: 0173  IOM6 B: 0173
      Shelf 2: DS2246  Firmware rev. IOM6 A: 0173  IOM6 B: 0173
      Shelf 3: DS2246  Firmware rev. IOM6 A: 0173  IOM6 B: ----
      Shelf 4: DS2246  Firmware rev. IOM6 A: 0173  IOM6 B: 0173
New to NetApp?
  • この記事は役に立ちましたか?
