メインコンテンツへスキップ
アクティブラーニングサイクル中のNVMEMバッテリアラート
697
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • FAS2620
  • FAS2750 / FAS2720
  • ONTAP 9
問題
  • EMSログから、node01のNVRAMバッテリーが危険なほど低下しています。
[node01: statd: monitor.nvramLowBattery:EMERGENCY]: NVRAM battery is dangerously low.
[node01: statd: monitor.nvramLowBattery.notice:notice]: If the NVRAM battery is dangerously low, the system shuts down automatically every 24 hours to encourage you to replace it. If you reboot the system it will run for another 24 hours before shutting down.
[node01: statd: callhome.battery.low:alert]: Call home for BATTERY_LOW.
[node01: statd: monitor.shutdown.nvramLowBattery.pending:alert]: NVRAM battery is dangerously low. Halting system in 24 hours. Replace the battery immediately!
  • 2時間後、SNMPトラップ「dhmNoticeDegradedIO」が顧客の監視サーバーに送信されます。
Unsupported Alert,2022/11/02 03:00:12,xxxxxxxx,node01(primary external storage)_tenant 00006100,[failure][node01]dhmNoticeDegradedIO,NNMI_INCIDENT,Run
  • SPログから、その時点でNVRAMバッテリ学習サイクルが実行されていることがわかります。
SP events all
[IPMI.notice]: 7e02 | 02 | EVT: 0301ffff | Bat_Lrn_Active | Assertion Event, "State Asserted"
[IPMI.notice]: 7f02 | 02 | EVT: 01500005 | Bat_Dstg_Cycles | Assertion Event, "Lower Non-critical going low "
[IPMI.notice]: 8002 | 02 | EVT: 01520002 | Bat_Dstg_Cycles | Assertion Event, "Lower Critical going low "
[IPMI.notice]: 8102 | 02 | EVT: 81520402 | Bat_Dstg_Cycles | Deassertion Event, "Lower Critical going low "
[IPMI.notice]: 8202 | 02 | EVT: 81500d05 | Bat_Dstg_Cycles | Deassertion Event, "Lower Non-critical going low "
[IPMI.notice]: 8302 | 02 | EVT: 0301ffff | Attn_Sensor1 | Assertion Event, "State Asserted"
[IPMI.notice]: 8402 | 02 | EVT: 0300ffff | Attn_Sensor1 | Assertion Event, "State Deasserted"
[IPMI.notice]: 8502 | 02 | EVT: 0300ffff | Bat_Lrn_Active | Assertion Event, "State Deasserted"
SP LATEST IPMI
LrnCycleStartDate : 22-11-01-12:00
LrnCycleStartFCC  : 0x052f
LrnCycleEndFCC   : 0x0347
LrnCycleEndDate   : 22-11-01-18:30
New to NetApp?
