メインコンテンツへスキップ
複数のシャーシファンが故障:MBが原因でシステムは2分後にシャットダウンします
21
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
環境
  • ONTAP 9
  • AFFシステム
  • ASAシステム
  • FASシステム
問題
  • 1つのノードでそれ以降のファン障害が頻繁に報告される:
  • イベントログには次のログが表示される:
Sat Apr 29 20:58:32 -0700 [NodeB: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan3_1 (failed)
Sat Apr 29 20:58:32 -0700 [NodeB: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan3_2 (failed)
Sat Apr 29 20:58:37 -0700 [NodeB: env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
Sat Apr 29 20:59:00 -0700 [NodeB: monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed: SysFan3 F2, SysFan3 F1.
Sat Apr 29 20:59:02 -0700 [NodeB: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan3_1
Sat Apr 29 20:59:02 -0700 [NodeB: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan3_2
Sat Apr 29 21:01:02 -0700 [NodeB: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
Sun May 28 14:52:19 -0700 [NodeB: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan4_1 (failed)
Sun May 28 14:52:19 -0700 [NodeB: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan4_2 (failed)
Sun May 28 14:52:24 -0700 [NodeB: env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
Sun May 28 14:52:49 -0700 [NodeB: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan4_1
Sun May 28 14:52:49 -0700 [NodeB: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan4_2
Sun May 28 14:53:00 -0700 [NodeB: monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed: SysFan4 F2, SysFan4 F1.
Sun May 28 14:54:49 -0700 [NodeB: env_mgr: monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Multiple fans failed)
Fri Jun 02 03:21:48 -0700 [NodeB: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan1_1 (failed)
Fri Jun 02 03:21:48 -0700 [NodeB: env_mgr: monitor.chassisFan.stop:error]: Chassis fan contains at least one stopped fan: Fan1_2 (failed)
Fri Jun 02 03:21:53 -0700 [NodeB: env_mgr: monitor.chassisFanFail.xMinShutdown:EMERGENCY]: Multiple Chassis Fan failure: System will shut down in 2 minutes.
Fri Jun 02 03:22:00 -0700 [NodeB: monitor: monitor.globalStatus.critical:EMERGENCY]: Multiple fans has failed: SysFan1 F2, SysFan1 F1.
Fri Jun 02 03:22:18 -0700 [NodeB: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan1_1
Fri Jun 02 03:22:18 -0700 [NodeB: env_mgr: callhome.c.fan.fru.fault:error]: Call home for CHASSIS FAN FRU FAILED: Fan1_2
Fri Jun 02 03:22:48 -0700 [NodeB: env_mgr: callhome.c.fan.fru.shut:error]: Call home for MULTIPLE CHASSIS FAN FAILED: System will shut down in 2 minutes
  • ファンモジュールの交換では問題は解決しない。
New to NetApp?
