メインコンテンツへスキップ
PCIeモジュールの問題により、起動時にノードの電源が再投入される
16
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • AFF-A70
  • X50133A
問題
  • 次のエラーでONTAPを起動するとノードが再起動します:
e3b: port_rcv_data failed.
e3c: port_rcv_data failed.
e3d: port_rcv_data failed.
e3a: port_rcv_data failed.
e3a: ERR: NTAP_power_cycle_after_firmware_dump: fatal error occured with firmware dump collected and will power-cycle to recover...
または
e3a: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3b: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3c: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3d: ERR: mlx5e_open_locked:4358:(pid 4954): mlx5e_open_tises failed, -5
e3a: ERR: mlx5e_media_change:772:(pid 4954): Query port media capability failed
e3a: ERR: mlx5e_open:4421:(pid 4954): Setting port status to up failed
e3b: ERR: mlx5e_ioctl:4994:(pid 34434): Query module num failed, eeprom reading is not supported
e3c: ERR: mlx5e_ioctl:4994:(pid 34434): Query module num failed, eeprom reading is not supported
e3d: ERR: mlx5e_ioctl:4994:(pid 34434): Query module num failed, eeprom reading is not supported
e3a: ERR: mlx5e_ioctl:4994:(pid 34438): Query module num failed, eeprom reading is not supported
e3b: ERR: mlx5e_ioctl:4994:(pid 39252): Query module num failed, eeprom reading is not supported
e3c: ERR: mlx5e_ioctl:4994:(pid 39252): Query module num failed, eeprom reading is not supported
e3d: ERR: mlx5e_ioctl:4994:(pid 39252): Query module num failed, eeprom reading is not supported
e3a: ERR: mlx5e_ioctl:4994:(pid 39256): Query module num failed, eeprom reading is not supported
e3d: ERR: NTAP_power_cycle_after_firmware_dump: fatal error occured with firmware dump collected and will power-cycle to recover...
  • 電源の再投入と ONTAP の起動後、スロット 3 のすべてのポートはオンラインになりません。
New to NetApp?
