メインコンテンツへスキップ
ONTAPシステムの健全性と環境に関するレポート:デグレード、使用不可、障害状態のPSUがある
123
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • AFF/FASプラットフォーム
  • 電源装置
問題
  • ONTAP CLIレポート:
::> system health subsystem show
   Environment    degraded
::> system node environment sensors show
   Node Sensor         State         Value/Units Crit-Low   Warn-Low    Warn-Hi    Crit-Hi
       PSU1 VIN     not-available   - mV      90480      93600      261040     263120
       PSU1 VOUT     not-available   - mV      11336      11440     12948     13156
       PSU1 Curr IIN    not-available   - mA     0        -         9984      12012
       PSU1 IOUT     not-available   - mA     0        -         130000     132000
       PSU1 PIN      not-available   - W      7        14        1611      1796
       PSU1 POUT     not-available   - W      7        14        1611      1796
       PSU1 Inlet      failed        - C      0        -        58      63
       PSU1 Hot      failed        - C      0        -        100      105
       PSU1 FB Hot    failed       - C      0        -        100      105
       PSU1 FAN      not-available   - RPM      800       1200      -       -
  • EMS ログでは次のイベントが継続的に報告されます:
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 VIN is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 VOUT is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Curr IIN is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 IOUT is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 PIN is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 POUT is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Inlet is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Hot is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 FB Hot is Unreadable
Thu Sep 10 18:31:27 +0200 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 FAN is Unreadable
Thu Sep 10 18:35:56 +0200 [Node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (PSU1 Inlet) is not readable.
Thu Sep 10 18:35:56 +0200 [Node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (PSU1 Hot) is not readable.
Thu Sep 10 18:35:56 +0200 [Node-01: env_mgr: monitor.temp.unreadable:error]: The controller temperature (PSU1 FB Hot) is not readable.
または
Thu Mar 06 07:45:07 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 In Volt is Unreadable
Thu Mar 06 07:45:17 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 In Curr is Unreadable
Thu Mar 06 07:45:17 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 12V Out Volt is Unreadable
Thu Mar 06 07:45:17 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 12V Out Curr is Unreadable
Thu Mar 06 07:45:28 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.off:notice]: Chassis power supply 2 off.
Thu Mar 06 07:45:28 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 In Pwr is Unreadable
Thu Mar 06 07:45:28 +0100 [Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 2 is degraded: PSU2 Out Pwr is Unreadable
New to NetApp?
