メインコンテンツへスキップ
スイッチ-クラスタのHealth degraded:SFPが存在しないことを報告するパートナースイッチインターフェイス
41
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
hw
Last Updated:
環境
Cisco NXxxxxクラスタスイッチ
問題
EMSログ
HA Group Notification (Health Monitor process cshm: SwitchIfIslDownWarn_Alert[node02-switch1(FOX000000D2)/Ethernet1/44]) ALERT
 ONTAP CLI
::*> system health alert show Node: node2 Resource: Link Aggregate 10 Alert ID:SwitchIfIslDownWarn_Alert Severity: Major Indication Time: Tue Jun 11 12:26:15 2019 Suppress: false Acknowledge: false Probable Cause: The cable used to connect switch "switch1/ Link Aggregate 10" to the ISL port might be faulty. Possible Effect: Cluster redundancy might be lost. Corrective Actions: 1) Check whether the cable is fully inserted into the interface port on both ends. 2) Reconnect the ISL port using another cable. After reconnecting it, verify whether the link of the ISL port is up by executing the commands as per switch configuration guide or by checking whether the Link status LED is on.
show tech-supportの出力
スイッチ1はインターフェイス1/44のこの情報を提供しました。
interface 1/44 is showing down.
Ethernet1/44 is down (Link not connected)
スイッチ2 はこの情報をインターフェイス1/44に提供しました。
  • show interface transceiver logsセクションのログ
switch2# show interface transceiver
Ethernet1/44
transceiver is not present
New to NetApp?
