メインコンテンツへスキップ
システムストレージ構成:ケーブル不良によるパスの混在
69
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
環境
ONTAP 9
問題
  • Mixed-path sysconfig -a の出力にSystemStorage Configurationと表示されます。
  • system health alert show 同じレポート
::> system health alert show
Node: node01
Resource: Shelf 4.11
Severity: Major
Indication Time: Tue Jan 30 21:00:54 2024
Suppress: false
Acknowledge: false
Probable Cause: Controller JC8FAS02-03 has only a single-path configuration to disk shelf 4.11. This might occur when the controller does not have dual-path
configuration to stack 4, a SAS HBA port on the controller connected to the disk shelf is disabled, or shelf-to-shelf cabling is incorrect.
  • EMSログ:
Fri Apr 07 15:26:37 [node01:dsa_disc: ses.multipath.ReqError:alert]: SAS disk shelf detected without a multipath configuration.
Fri Apr 07 15:26:37 [node01:dsa_disc: shelf.config.mixedha:notice]: System is using a mixture of single path, multi-path or quad-path HA storage configurations.
Fri Apr 07 15:26:29 [node02: dsa_disc: ses.multipath.ReqError:alert]: SAS disk shelf detected without a multipath configuration.
Fri Apr 07 15:26:29 [node02: dsa_disc: shelf.config.mixedha:notice]: System is using a mixture of single path, multi-path or quad-path HA storage configurations.
  • IOMモジュールの障害LEDは点灯しない
  • シェルフパスを確認するにはsystem node run -node {nodename|local} -command sasadmin expander_map、コンソールからコマンドを実行するか、ASUPの「sas-expander-map」を調べます。
Node01: ポート0cは  IOM Aでシェルフ10/11/12に接続し(シェルフ13/14がない)、ポート2dは シェルフ14/13/12/11/10にIOM Bで接続します。
Expanders on channel 0c:
Level   1: WWN 500a098008657ca9, ID 10, Serial Number ' SHJSG2234000411', Product 'DS22412IOM12A  ', Rev '0300', Slot A
Level   2: WWN 500a098008657cb9, ID 11, Serial Number ' SHJSG2234000394', Product 'DS22412IOM12A  ', Rev '0300', Slot A
Level   3: WWN 500a09800865817d, ID 12, Serial Number ' SHJSG2234000050', Product 'DS22412IOM12A  ', Rev '0300', Slot A
Expanders on channel 2d:
Level   1: WWN 500a098008658569, ID 14, Serial Number ' SHJSG2234000373', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   2: WWN 500a098008658415, ID 13, Serial Number ' SHJSG2234000381', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   3: WWN 500a098008657ea5, ID 12, Serial Number ' SHJSG2234000050', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   4: WWN 500a098008657b35, ID 11, Serial Number ' SHJSG2234000394', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   5: WWN 500a098008657c95, ID 10, Serial Number ' SHJSG2234000411', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Node02: ポート0cは IOM Bでシェルフ10/11/12/13/14に接続し、ポート2dは シェルフ14/13とIOM Aに接続します(シェルフ12/11/10は搭載されていません)。
Level   1: WWN 500a098008657c95, ID 10, Serial Number ' SHJSG2234000411', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   2: WWN 500a098008657b35, ID 11, Serial Number ' SHJSG2234000394', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   4: WWN 500a098008658415, ID 13, Serial Number ' SHJSG2234000381', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   5: WWN 500a098008658569, ID 14, Serial Number ' SHJSG2234000373', Product 'DS22412IOM12A  ', Rev '0300', Slot B
Level   1: WWN 500a098008658585, ID 14, Serial Number ' SHJSG2234000373', Product 'DS22412IOM12A  ', Rev '0300', Slot A
Level   2: WWN 500a098008658511, ID 13, Serial Number ' SHJSG2234000381', Product 'DS22412IOM12A  ', Rev '0300', Slot A
New to NetApp?
  • この記事は役に立ちましたか?
