コントローラの温度(システムコンセント)が読み取れません
環境
- FAS8300
- BMCフリムウェア13.8
問題
EMS
3/14/2024 14:17:35 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 13:17:35 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 12:17:35 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 11:17:35 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 10:17:34 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 09:17:34 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 08:17:34 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 07:17:34 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 06:17:34 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 05:17:34 node-01 ERROR monitor.temp.unreadable: The controller temperature (System Outlet) is not readable.
3/14/2024 09:18:02 node-01 ERROR callhome.chassis.hitemp: Call home for CHASSIS OVER TEMPERATURE
環境ステータス
System Inlet normal 23 C 0 C 5 C 46 C 49 C
CX5 Inlet normal 37 C 0 C 5 C 60 C 70 C
System Outlet failed -- C 0 C 5 C 58 C 61 C
NVMe Temp normal 25 C 0 C 5 C 60 C 70 C
LED1 Temp normal 23 C 0 C 3 C 43 C 46 C
LED2 Temp normal 23 C 0 C 3 C 43 C 46 C
MP Temp1 normal 21 C 0 C 5 C 45 C 48 C
SP -最新- IPMI
Log Collection Time: Thu Mar 21 01:55:13 2024
Self Test: (run for 0 sec)
Selftest: passed
Sensor Reading: (run for 1 sec)
PilotIV | 00h | ok | 0.1 | Dynamic MC @ 20h
PVCCIN_CPU0 | 01h | ok | 21.1 | 1.77 Volts
PVCCIN_CPU1 | 02h | ok | 21.1 | 1.77 Volts
PVDDQ_ABC | 03h | ok | 21.1 | 1.21 Volts
PVDDQ_DEF | 04h | ok | 21.1 | 1.21 Volts
PVDDQ_GHI | 05h | ok | 21.1 | 1.21 Volts
PVDDQ_KLM | 06h | ok | 21.1 | 1.21 Volts
P1V05_PCH | 07h | ok | 21.1 | 1.03 Volts
System_Inlet | 10h | ok | 7.1 | 22 degrees C
CX5_Inlet | 11h | ok | 7.2 | 37 degrees C
System_Outlet | 12h | ns | 7.3 | No Reading
NVMe_Temp | 13h | ok | 7.4 | 25 degrees C
