メインコンテンツへスキップ
Transient AutoSupport ( BATTERY ( BATTERY LOW )通知メッセージ
55
Visibility:
Internal
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
環境
  • AFF A250
  • BMC ファームウェア15.2
問題
  • EMSメッセージ
HA Group Notification from node_name (BATTERY(capacity low)) NOTICE
  • 一方または両方のノードで同じ問題が報告され、数秒後にクリアされました。
Fri Aug 06 10:15:39 +0200 [node_name_1: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Fri Aug 06 10:16:39 +0200 [node_name_1: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Fri Aug 06 10:32:49 +0200 [node_name_1: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
Thu Aug 05 00:02:49 +0200 [node_name_2: env_mgr: nvmem.battery.capLowWarn:error]: The NVMEM battery capacity is below normal (5 cycles).
Thu Aug 05 00:03:49 +0200 [node_name_2: env_mgr: callhome.battery.notice:notice]: Call home for BATTERY (capacity low) NOTICE.
Thu Aug 05 00:32:09 +0200 [node_name_2: env_mgr: nvmem.battery.capNormal:notice]: The NVMEM battery capacity is normal.
  • その他の関連エラーは報告されていません。
  • BMC / e0M ポートでは大量のトラフィックが検出されます。例:
eth0    Link encap:Ethernet  HWaddr D0:39:EA:47:11:31
      inet addr:192.168.0.1  Bcast:192.168.0.255  Mask:255.255.255.0
      UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
      RX packets:539889 errors:0 dropped:277459 overruns:0 frame:0
      TX packets:8 errors:0 dropped:0 overruns:0 carrier:0
      collisions:0 txqueuelen:1000
      RX bytes:54208615 (51.6 MiB)  TX bytes:624 (624.0 B)
      Interrupt:32
-- interface  e0M  (34 days, 11 hours, 25 minutes, 25 seconds) --
RECEIVE
 Total frames:    110m| Frames/second:    37  | Total bytes:    20986m
 Bytes/second:    7045  | Total errors:     0  | Errors/minute:     0
 Total discards:    0  | Discards/minute:    0  | Multi/broadcast:   569k
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
