メインコンテンツへスキップ
バッテリ センサーが読み取り不能であることによるノードのシャットダウン
122
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
hw
Last Updated:
環境
  • ONTAP 9
  • BMC
  • バッテリ
問題
  • ノードで突然環境シャットダウンが実行される。EMSログでは次の情報を確認できます:
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Curr' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Charge Curr' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Initial FCC' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:nvmem.battery.packInvalid:EMERGENCY]: The incorrect NVMEM battery is installed. Expected part number is 271-00045. To prevent data loss, the system will shut down in 5 minutes.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Volt' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Full Cap' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Charge Volt' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Dstg Cycles' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Dcharge FET' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:callhome.battery.failure:EMERGENCY]: Call home for BATTERY ('Bat Charge FET' unreadable) CRITICAL.
XXX XX XX:XX:XX [Cluster1:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery current critical)
  • 読み取り不能なセンサーからBMCが回復されました
Record 338: Sat Nov 08 00:11:11.149382 2025 [IPMI.warning]: Recovering BMC due to a non-readable sensor
  • バッテリー学習サイクルの開始と失敗が確認されます
Record 409: Sat Nov 08 12:05:11.263893 2025 [IPMI.notice]: 0416 | 02 | EVT: 6f06ffff | Bat_Status | Assertion Event, "Learn Cycle"
Record 410: Sat Nov 08 15:17:02.842815 2025 [BMC.notice]: Battery Learning cycle failed with error 0x88
Record 411: Sat Nov 08 15:17:13.542179 2025 [IPMI.notice]: 0417 | 02 | EVT: ef06ffff | Bat_Status | Deassertion Event, "Learn Cycle"
  • 次に、NVMEMバッテリの読み取り不能センサーのアラートが原因でノードがリブートします
Record 468: Sun Nov 09 00:12:49.406520 2025 [IPMI.emergency]: env_mgr triggers OS halt:Battery temp unreadable for 2 mins
Record 469: Sun Nov 09 00:13:23.584592 2025 [Controller.notice]: Appliance user command halt.
Record 470: Sun Nov 09 00:13:23.624175 2025 [IPMI.notice]: 0451 | 02 | EVT: 6f03ffff | Sensor 255 | Assertion Event, "Storage OS graceful shutdown"
Record 471: Sun Nov 09 00:13:25.340475 2025 [IPMI Event.critical]: System power down
Record 472: Sun Nov 09 00:13:25.344857 2025 [IPMI.emergency]: Data ONTAP initiated shutdown
New to NetApp?
