システムの電源再投入後、「 system service-event show 」に「 CNA0_Rst : Sensor 105 fault 」と表示されます
に適用されます
- FAS2720
- ONTAP 9.5P13
問題
Voltage Sensorシステムの電源再投入時に、次のような「」関連エラーが多数発生します。
例:
::> system controller service-event showNode ID Event Location Event Description---------------- --- ---------------------------------- ----------------------***** 1 Controller A on Chassis 1 PVCCIN_CPU: Voltage Sensor 18 LNC***** 2 Controller A on Chassis 1 PVCCIN_CPU: Voltage Sensor 18 LCR***** 3 Controller A on Chassis 1 P5V: Voltage Sensor 20 LCR***** 4 Controller A on Chassis 1 PVDDQ_DDR4_AB: Voltage Sensor 21 LCR***** 5 Controller A on Chassis 1 PVTT_DDR4_AB: Voltage Sensor 24 LNC***** 6 Controller A on Chassis 1 PVTT_DDR4_AB: Voltage Sensor 24 LCR***** 7 Controller A on Chassis 1P3V3: Voltage Sensor 25 LNC***** 8 Controller A on Chassis 1 P12V: Voltage Sensor 32 LNC***** 9 Controller A on Chassis 1 P12V_Curr: Current Sensor 34 LCR***** 10 Controller A on Chassis 1 CPU_Cat_Error: Temperature Sensor 97 Fault***** 11 Controller A on Chassis 1 CNA0_Rst: Sensor 105 Fault11 entries were displayed.- 障害 LED が点灯。
