メインコンテンツまでスキップ
ヘルスモニタプロセスのホームの呼び出し nphm : Data ONTAP の bootmediaReplaceAlert
109
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
に適用されます
  • FASシリーズ
  • AFFシリーズ
問題
  • Data ONTAP でヘルスアラート「 BootmediaReplaceAlert 」が生成される
  • EMS ログでアラートが報告されます。
Sun Aug 16 00:36:02 CDT [system2-01: mgwd: callhome.hm.alert.critical:alert]: Call home for Health Monitor process nphm: BootmediaReplaceAlert[mSATA (serial-number-of-boot-device)].
  •  runコマンド
     ::> system health alert show
  • または、 AIQ ポータル( system-health-alert-persistent.xml セクション)を使用して AutoSupport を使用して確認します。
 Node system2-01 Monitor controller Alert ID BootmediaReplaceAlert Alerting Resource mSATA (serial-number-of-boot-device) Subsystem Motherboard Indication Time Sun Aug 16 00:34:48 2020 Perceived Severity Critical Probable Cause hardware_degrading Description Bad sector count in the boot media has reached critical level. Corrective Actions 1. Contact technical support to obtain a new boot device. 2. If possible, perform a takeover of this node and bring the node down for maintenance. 3. Refer to the "Boot media replacement guide for your given hardware platform" to replace the boot device. 4. Update the boot device with the appropriate Data ONTAP version. 5. Bring the storage system online. Possible Effect Upgrading, downgrading, reverting, or applying patches to Data ONTAP can damage the boot device. If the boot device is damaged, the storage system will not boot. Acknowledge false Suppress false Policy BootmediaReplaceAlertPolicy Acknowledger Suppressor Additional Information Vendor ID(in Hex): 8086 Device ID(in Hex): 8d02 Display Name: BootMedia Usbmon Status: present Device State: bad Size(in MB): 114473
New to NetApp?
