メインコンテンツへスキップ
FlexVol volumeで二次圧縮を有効にするとエラーが発生する
61
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2010034571</a>
Last Updated:
環境
ONTAP 9
問題
FlexVol volumeで二次圧縮を有効にしようとしたときにエラーが発生しました:
::>volume efficiency modify -vserver vs1 -volume vol1 -compression true -compression-type secondary
"Error: command failed: Failed to modify efficiency configuration for volume "vol1" of Vserver "vs1": Failed to set compression type and application I/O size on the volume. Switching between compression type or application I/O size is allowed only after undoing the compression savings on the volume."
New to NetApp?
