メインコンテンツへスキップ
LIFフェイルオーバーポリシーの割り当てが正しくないため、ノードのテイクオーバーを実行できません
173
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core<a>2009441663年</a>
Last Updated:
環境
  • ONTAP 9
  • FAS / AFF の略
  • SAN LIF
問題
  • ノードのテイクオーバーが次のエラーで失敗します。
cluster1::> storage failover takeover -ofnode Node1
  (storage failover takeover)
Warning: A takeover will be initiated. When the partner node reboots, a giveback
     will be automatically initiated. Do you want to continue?
      {y|n}: y
Error: command failed: Could not migrate LIFs away from node "Node1":
    Reason Failed to migrate one or more LIFs away from node
    "Node1". Use the "network interface show -curr-node
    Node1" command to identify LIFs that could not be migrated off
    that node. Use the "network interface migrate" command to manually
    migrate the LIFs off the node. Run "storage failover show" to confirm
    node "Node1" is operational.  If node is operational, reissue
    the takeover command with "-skip-lif-migration-before-takeover" to skip
    the migration and proceed with takeover.
  • 使用中のLIFはSANベースです。
New to NetApp?
