メインコンテンツへスキップ
特定のNICケーブルの切断テストでASUPが生成されないのはなぜですか?
190
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
環境
  • ONTAP 9
  • AutoSupport(ASUP)
回答
ネットワークケーブルの切断テストでは、ONTAPのデフォルト設定が原因で、特定のNICの切断時にASUPが生成されません。
  • 観察された動作:
  1. Service(Data)NIC Cable Disconnection  - ASUPメッセージは生成されません。
EMSログ:
[node: intr: netif.linkDown:info]: Ethernet e2a: Link down, check cable.
[node: intr: net.ifgrp.lacp.link.inactive:error]: ifgrp a0a, port e2a has transitioned to an inactive state. The interface group is in a degraded state.
[node: vifmgr: vifmgr.portdown:notice]: A link down event was received on node node, port e2a.
  1. Cluster Interconnect NIC Cable Disconnection - ASUPメッセージは生成されません。
EMSログ:
[node: intr: netif.linkDown:info]: Ethernet e1a: Link down, check cable.
[node: vifmgr: vifmgr.portdown:notice]: A link down event was received on node node, port e1a.
[node: vifmgr: vifmgr.clus.linkdown:EMERGENCY]: The cluster port e1a on node node has gone down unexpectedly.
[node: vifmgr: vifmgr.lifmoved.linkdown:notice]: LIF node_clus2 (on virtual server 4294967293), IP address 169.254.254.83, is being moved to node node, port e0a.
[node: vifmgr: vifmgr.reach.noreach:notice]: Network port e1a on node node cannot reach its expected broadcast domain Cluster:Cluster. No other broadcast domains appear to be reachable from this port.
  1. HA-Interconnect NIC Cable Disconnection - ASUPメッセージ「HA interconnect down」が生成されます。
EMSログ:
[node: statd: ic.HAInterconnectDown:error]: HA interconnect: Interconnect down for 2 minutes: link0 down
[node: statd: callhome.hainterconnect.down:alert]: Call home for HA INTERCONNECT DOWN due to link0 down.
  1. Disk Shelf Connection NIC Cable Disconnection - ASUPメッセージ「disk redundancy failed」が生成されます。
EMSログ:
[node: intr: netif.linkDown:info]: Ethernet e4a-30: Link down, check cable.
[node: intr: nvmeof.timeout:notice]: Timeout on subnqn nqn.2014-08.org.nvmexpress.discovery, controller ID 9, qpair ID 0, sequence number 3704.
[node: intr: nvmeof.timeout:notice]: Timeout on subnqn nqn.2014-08.org.nvmexpress:1b96:1b96:241163800956:X4032WCOFB15TNVE, controller ID 9, qpair ID 0, sequence number 2017.
[node: intr: nvmeof.timeout:notice]: Timeout on subnqn nqn.2014-08.org.nvmexpress:1b96:1b96:241025800131:X4032WCOFB15TNVE, controller ID 9, qpair ID 0, sequence number 2066.
[node: dsa_disc: callhome.dsk.redun.fault:error]: Call home for DISK REDUNDANCY FAILED.
  • 理由:
    • HAインターコネクトNICとディスクシェルフNICを切断すると、 hainterconnect.down 次のようにASUP」とdsk.redun.faultが送信されるように定義されます。
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *hainterconnect.down*
node     autosupport-message to    noteto
ontap914-01 hainterconnect.down enabled enabled
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *dsk.redun*
ontap914-01 dsk.redun.fault    enabled enabled
  • ただし、 サービス(データ)NIC とクラスタインターコネクトNICを切断する と、 netif.linkDown と vifmgr.portdown  などがASUPを送信するように定義されていません。
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *net*
ontap914-01 clus.net.degraded   enabled enabled
ontap914-01 mcc.network.stats   disabled disabled
ontap914-01 netif.fatal.error   enabled enabled
ontap914-01 netif.init.failed   enabled enabled
ontap914-01 netif.uncorEccError enabled enabled
ontap914-01 netinet.dup.clustIP enabled enabled
6 entries were displayed.
ontap914::> system node autosupport trigger show -fields autosupport-message,to,noteto -node ontap914-01  -autosupport-message *vifmgr*
There are no entries matching your query.
追加情報
AdditionalInformation_text
