メインコンテンツへスキップ
アグリゲートは、二重デグレードまたは二重再構築状態にあります
26
Visibility:
Votes:
0
Category:
data-ontap-7
Specialty:
7dot
Last Updated:
環境
  • Data ONTAP 7以前
  • ONTAP 9
  • ディスクドライブ
問題
アグリゲートが「ダブルデグレード」または「ダブル再構築」の状態です。
::> run * sysconfig -r
Aggregate aggr0 (online, raid_dp, reconstruct) (block checksums)
Plex /aggr0/plex0 (online, normal, active, pool0)
RAID group /aggr0/plex0/rg0 (double reconstruction 11% completed)
RAID Disk      Device   HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)  Phys (MB/blks)
dparity          0a.16    0a    1   0   FC:B   0  FCAL 15000 418000/856064000 420156/860480768
parity           0a.17    0a    1   1   FC:B   0  FCAL 15000 418000/856064000  420156/860480768
data             0d.28    0d    1   12  FC:A   0  FCAL 15000 418000/856064000 420156/860480768
data             0a.25    0a    1   9   FC:B   0  FCAL 15000 418000/856064000  420156/860480768
data             0d.29    0d    1   13  FC:A   0  FCAL 15000 418000/856064000 420156/860480768 (reconstruction 11% completed)
data             0a.24    0a    1   8   FC:B   0  FCAL 15000 418000/856064000  420584/861357448 (reconstruction 11% completed)
double degraded status:
Aggregate aggr1 (offline, raid_dp, degraded) (block checksums)
  Plex /aggr0(1)/plex0 (online, normal, active, pool0)
    RAID group /aggr1/plex0/rg0 (double degraded)
dparity          0c.00.7  0c    0   7   SA:B   0  SATA  7200 423111/866531584 423946/868242816
parity               FAILED           N/A                   423111/866531584
data                 FAILED           N/A                   423111/866531584
::> aggr status
Aggr State           Status            Options
aggr0 online        raid_dp, aggr     root, diskroot, nosnap=off,
                    reconstruct       raidtype=raid_dp, raidsize=16,
                                      ignore_inconsistent=off,
                                      snapmirrored=off,
                                      resyncsnaptime=60,
                                      fs_size_fixed=off,
                                      snapshot_autodelete=on,
                                      lost_write_protect=on,
                                      no_delete_log=off
        Volumes: vol1,vol2, vol3
        Plex /aggr0/plex0: online, normal, active
           RAID group /aggr0/plex0/rg0: double reconstruction 11% completed
New to NetApp?
