メインコンテンツへスキップ
HTTPSを使用してONTAP AutoSupportメッセージが失敗する:SSL証明書の問題
668
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core
Last Updated:
環境
  • ONTAP 9
  •  AutoSupportメッセージ用のHTTPS転送プロトコル
問題
  • HTTPSを転送プロトコルとして使用すると、AutoSupportメッセージが失敗します。
::> system node autosupport history show -node node_name -seq-num <seq_num> -instance
                 Node: node_name
     AutoSupport Sequence Number: seq_num
   Destination for This AutoSupport: https
            Trigger Event: callhome.management.log
         Time of Last Update: 1/12/2021 02:58:59
          Status of Delivery: transmission-failed
          Delivery Attempts: 15
         AutoSupport Subject: MANAGEMENT_LOG
             Delivery URI: 10.106.130.129:8080(support.netapp.com/put/AsupPut)
              Last Error: SSL certificate problem: unable to get local issuer certificate
::> autosupport check show-details -node node_name
      Node: node_name
    Category: http-https
   Component: http-put-destination
     Status: failed
     Detail: HTTP/S PUT connectivity check failed for destination:
           https://support.netapp.com/put/AsupPut/ via proxy -
           123.123.123.123:8080. Error: Peer certificate can not be
           authenticated with given Certificate Authority
           certificates.
 Corrective Action: Certificate issue. Please make sure you have the correct
           Root Certificate installed
   Component: http-post-destination
     Status: failed
     Detail: HTTP/S POST connectivity check failed for destination:
           https://support.netapp.com/asupprod/post/1.0/postAsup
           via proxy - 123.123.123.123:8080. Error: Peer certificate
           can not be authenticated with given Certificate
           Authority certificates.
  • 同様のエラーメッセージ:
    • message: SSL certificate problem: self signed certificate in certificate chain
    • Error: Peer certificate 指定したで認証できません Certificate Authority certificates.
    • Error: asup.post.drop: AutoSupport message (HA Group Notification from node01 (USER_TRIGGERED (TEST:Test)) NOTICE) was not posted to NetApp. The system will drop the message.
  • /mroot/etc/log/mlog/notifyd.log にはその他のエラーメッセージが表示されます。
::> system node run -node <node_name> -command rdfile /etc/log/mlog/notifyd.log
原因
  • support.netapp.com とストレージコントローラ間の通信パスの中間にあるファイアウォールや透過型プロキシなどのネットワークデバイスが HTTPS パケットを傍受している
  • ファイアウォールまたは透過型プロキシによって挿入された証明書はsupport.netapp.com によって提供されているように見えますが、証明書はONTAPの信頼ストアにインストールされていません。
  • support.netApp.com は、次のデフォルトの署名済み証明書を想定します (信頼ストアバンドルにはすでに存在します)。
::*> security certificate show -vserver <cluster_svm> -common-name AAACertificateServices
Vserver    Serial Number   Common Name                            Type
cluster_svm
           01              AAACertificateServices                 server-ca
    Certificate Authority: AAA Certificate Services
          Expiration Date: Sun Dec 31 18:59:59 2028
解決策
  1. ネットワーク/セキュリティチームにルートCA証明書を収集してsecurity certificate install を使用してONTAPにインストールするか、クラスタ内の各ノードを例外としてプロキシを変更して、プロキシが独自の自己署名証明書を挿入できないようにします。  たとえば、SSL復号化はpalo.tcw.intという共通名の証明書を挿入し、サポートをバイパスします。SSL復号化のためのNetApp .comは、SSL復号化による証明書の挿入を防ぎます。
  2. プロキシホワイトリストにsupport.netapp.com を追加します。
  3. プロキシを変更できない場合は、 一時的な回避策として証明書の検証を無効にすることができます。
::> system node autosupport modify -node <node_name> -validate-digital-certificate false
:これにより、クラスタ内のすべてのコントローラが、support.netapp.com から受信したサーバ証明書を検証しないように設定されます。これは、問題が完全に解決されるまでAutoSupportログの配信を再開するための一時的な修正です。
New to NetApp?
