メインコンテンツへスキップ
ボリュームSnapshotは自動的に削除されます
328
Visibility:
Votes:
0
Category:
data-ontap-8
Specialty:
core<a>1006210</a><a>FAS3140 - R5</a><a>Data ONTAP 8.1.2P2 7-Mode</a>
Last Updated:
環境
  • Data ONTAP 8
  • ONTAP 9
問題
Snapshotの保持期間が30日間設定されていても、ボリュームSnapshotは自動削除されます。
Snapshot autodelete settings for AUHVSNA1_SHARED:
                                        state=on
                                        commitment=try
                                        trigger=snap_reserve
                                        target_free_space=10%
                                        delete_order=oldest_first
                                        defer_delete=user_created
                                        prefix=(not specified)
                                        destroy_list=none =========================================
00000011.0010da6a 1b4cc5ac Tue Nov 25 2014 00:56:12  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'weekly.0' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da6c 1b4cc63c Tue Nov 25 2014 00:56:27  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'hourly.4' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da6e 1b4cc6d1 Tue Nov 25 2014 00:56:42  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'hourly.3' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da70 1b4cc758 Tue Nov 25 2014 00:56:55  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'hourly.1' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da72 1b4cc7f1 Tue Nov 25 2014 00:57:11  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'hourly.0' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da74 1b4cc888 Tue Nov 25 2014 00:57:26  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'nightly.0' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da76 1b4cc937 Tue Nov 25 2014 00:57:43  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'Dont_Delete_INC0752286' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da79 1b4cc9ab Tue Nov 25 2014 00:57:55  11:00 [disk.healthTrigger:warning] Disk 3a.42 received NHT health trigger (0x1 0xb 0x5d 0x5)
00000011.0010da7a 1b4cc9e9 Tue Nov 25 2014 00:58:01  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'Snapshot_4:45_24_11_2014' in volume 'AUHVSNA1_SHARED' to recover storage
00000011.0010da7c 1b4ccaa3 Tue Nov 25 2014 00:58:20  11:00 [wafl.volume.snap.autoDelete:info] Deleting snapshot 'Manual_snapshot' in volume 'AUHVSNA1_SHARED' to recover storage
As you can see here, On Nov 23, the volume /vol/AUHVSNA1_SHARED/ was at 96% capacity.  Something happened between Nov 23, and Nov 25 that pushed that volume to its capacity and snapshots were deleted on Nov 25 to save the volume.
Filesystem                         kbytes           used              avail    capacity  Mounted on
Nov 23
/vol/AUHVSNA1_SHARED/                               5653468812                 5424660856                  228807956      96%  /vol/AUHVSNA1_SHARED/
/vol/AUHVSNA1_SHARED/.snapshot             115376912                    87988840                      27388072      76%  /vol/AUHVSNA1_SHARED/.snapshot
Nov 25
/vol/AUHVSNA1_SHARED/                              5858989708                 5452568432                  406421276      93%  /vol/AUHVSNA1_SHARED/
/vol/AUHVSNA1_SHARED/.snapshot             119571216                    2969476                         116601740       2%  /vol/AUHVSNA1_SHARED/.snapshot
最も古いSnapshotは、オプションの指定に従って最初に削除されましたが、ボリュームを稼働させ続けるために、スペースの問題によってSnapshotの削除が維持されていました。つまり、ボリュームの容量が96%に達し、スペースが不足し、Snapshotの削除が十分な状態になるまで保持されていました。
その時点でボリュームを容量にプッシュする何らかの問題が発生し、すべてのSnapshotが削除されました。ボリュームスペースが許可されている場合、削除プロセスは1つのSnapshotで停止していましたが、ボリュームスペースでは許可されていません。
また、も target_free_space 10%に設定
target_free_spaceされています。「Snapshotコピーの自動削除」を参照してください。は、Snapshotコピーの削除を停止するタイミングを決定します。target_free_space ボリュームの割合の値を指定します。たとえば、20を指定すると、ボリュームの20%が空きスペースになるまでSnapshotコピーが削除されます。
一般 target_free_space 的には、Snapshotコピーが必要以上に削除されないように、値を自動削除のしきい値よりも2%低くします。
New to NetApp?
