メインコンテンツへスキップ
「 system node service-processor 」は、 SP のリブート後にデグレードステータスを表示します
867
Visibility:
Votes:
0
Category:
fas-systems<a>FAS8060</a><a>2008661216</a>
Specialty:
HW
Last Updated:
環境
  • FAS8020
  • FAS8040
  • FAS2620
  • FAS2650
  • FAS8200
  • Data ONTAP 9
  • Data ONTAP 8
問題
  • サービスプロセッサ( SP )をリブートすると、 SP のステータスがデグレードに変わります。
クラスタ::: * > system node service-processor reboot-sp -node *
Note: If your console connection is through the SP, it will be disconnected.
    Do you want to reboot the SP ? {y|n}: y
2 entries were acted on.
Cluster::*>
Cluster::*> system node service-processor
   autosupport image     network    reboot-sp   show     snmp
Cluster::*> system node service-processor show
                IP       Firmware
Node      Type Status    Configured   Version   IP Address
node-1  SP   rebooting   false     3.0.2    -
node-2  SP   rebooting   false     3.0.2    -
                IP       Firmware
node-1  SP   online    false     3.0.2    -
                IP       Firmware
node-2  SP   unknown    false     3.0.2    -
                IP       Firmware
node-2  SP  degraded  true      3.0.2    0.0.0.0
Cluster::> sp   ervice-p r processor show
  (system node service-processor show)
                IP       Firmware
node-2  SP  offline   true      3.0.2    0.0.0.0
  • node-1node-2の SP がオフラインになると、テイクオーバーが開始されます。
Cluster::> Feb 20 09:53:59 [node-2:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (SP IPMI Dead
Waiting for PIDS: /usr/sbin/ypbind 729.
Waiting for PIDS:  695.
Terminated
Uptime: 28d13h49m5s
System powering down...
System halting...
BIOS version: 9.3
Portions Copyright (c) 2011-2014 NetApp. All Rights Reserved
Waiting for SP ...
SP failure. Resetting SP from primary FW. This can take a few minutes
Waiting for SP ...
SP failure. Resetting SP from backup FW. This can take a few minutes
Waiting for SP ...
Failed to recover SP
IPMI PCI Slot Control failed.
IPMI:Get controller FRU inventory:failed
Phoenix SecureCore Tiano(TM)
Copyright 1985-2021 Phoenix Technologies Ltd.
All Rights Reserved
Build Date: 12/02/2014
*           9.3            *
*       PHOENIX SC-T 2009-2021       *
CPU = 1 Processor(s) Detected, Cores per Processor = 8
Intel(R) Xeon(R) CPU E5-2658 @ 2.10GHz
32768 MB System RAM Installed
256 KB L2 Cache
System BIOS shadowed
Video BIOS shadowed
USB Device: MICRON eUSB DISK
Boot Loader version 5.3
Copyright (C) 2000-2003 Broadcom Corporation.
Portions Copyright (C) 2002-2014 NetApp, Inc. All Rights Reserved.
BIOS POST Failure(s) detected: SP IPMI failure. Abort AUTOBOOT
  • node-2」を取り外して再接続すると、エラーをクリアできません。
LOADER-B> BIOS version: 9.3
Waiting for SP ...
Waiting for SP ...
Waiting for SP ...
All Rights Reserved
*           9.3            *
256 KB L2 Cache
Video BIOS shadowed
New to NetApp?
