メインコンテンツへスキップ
ヘルスモニタアラートSPNotConfiguredAlert
678
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • FAS
  • All Flashed FAS (AFF)
問題
  • AutoSupport (ASUP)レポートSPNotConfiguredAlert
  • system health alert show  コマンドを実行すると 、以下の詳細が表示されます。
例:
            Node: cluster-01
          Monitor: controller
          Alert ID: SPNotConfiguredAlert
     Alerting Resource: SP Config
         Subsystem: Service-Processor
      Indication Time: Wed Apr 24 14:42:27 2019
     Perceived Severity: Major
       Probable Cause: Configuration_error
        Description: Service Processor is not properly configured.
     Corrective Actions: 1. Use the "system service-processor network modify" command to configure the network interface                             of the Service Processor.
                            2. Use the "system service-processor image modify -node cluster-01 -autoupdate true" to                             configure AutoUpdate feature of the Service Processor.
                            3. Contact the technical support if the alert persists.
      Possible Effect: You might not be able to use the Service Processor to remotely access, monitor, and troubleshoot                             your storage system.
        Acknowledge: false
          Suppress: false
           Policy: SPNotConfiguredAlertPolicy
        Acknowledger: -
         Suppressor: -
   Additional Information: Status: online
               Configured: false
               Firmware Version: 5.5P1
               Booted Version :  primary
               Public Link Status:  down
               Warning Count: 7
               Link Warning Count: 8
   Alerting Resource Name: SP Config
   Additional Alert Tags: device
New to NetApp?
