メインコンテンツへスキップ
ノードはPSUの故障によりシステムヘルスアラートでCriticalPSUFruOffAlertを報告します
111
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
環境
  • ONTAP 9
  • FAS / AFFシステム
問題
  • ノードが健全性アラートでCriticalPSUFruOffAlert報告します。
ClusterA::> system health alert show -instance
            Node: Node-01
          Monitor: chassis
          Alert ID: CriticalPSUFruOffAlert
     Alerting Resource: xxxxxxx
         Subsystem: Environment
        Indication Time: Fri May 20 02:08:21 2022
             Severity: Critical
         Probable Cause: Loss_of_redundancy
           Description: PSU1 is off. The nodes in this chassis are Node-01, Node-02.
     Corrective Actions: 1. Check PSU1 and switch it on.
                     2. Refer to the Hardware specification guide for more information on the position of the                              power supply unit (PSU) and ways to check or replace it.
                     3. Contact support personnel if the alert persists.
  • イベントログでは、次のイベントが報告されます。
[Node-01: env_mgr: monitor.chassisPowerSupply.off:notice]: Chassis power supply 1 off.
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Temperature is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Current is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan1 Speed is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan1 Fault is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan2 Speed is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fan2 Fault is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Pwr Out OK is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Fault is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Over Temp is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Over Volt is Unreadable
[Node-01: env_mgr: monitor.chassisPowerSupply.degraded:notice]: Chassis power supply 1 is degraded: PSU1 Over Curr is Unreadable
[Node-01: power_low_monitor: monitor.chassisPower.degraded:alert]: Chassis power is degraded: Power Supply Status Critical: PSU1.
[Node-01: power_low_monitor: callhome.chassis.power:error]: Call home for CHASSIS POWER DEGRADED: Power Supply Status Critical: PSU1.
  • SPはPSUセンサーを次のように報告しますnasystem sensors出力:
SP Node-01> system sensors
Sensor Name    | Current   | Unit     | Status    | LCR     | LNC     | UNC     | UCR
PSU1_Present    | 0x0     | discrete   | Present   | na     | na     | na     | na
PSU1_Temp     | na      | degrees C  | na      | 0.000    | 5.000    | 50.000   | 60.000
PSU1_Curr     | na      | Amps     | na      | na     | na     | na     | na
PSU1_Fan1_Speed  | na      | RPM     | na      | 4500.000  | 4600.000  | na     | na
PSU1_Fan1_Fault  | na      | discrete   | na      | na     | na     | na     | na
PSU1_Fan2_Speed  | na      | RPM     | na      | 4500.000  | 4600.000  | na     | na
PSU1_Fan2_Fault  | na      | discrete   | na      | na     | na     | na     | na
PSU1_Status_OK   | na      | discrete   | na      | na     | na     | na     | na
PSU1_Pwr_In_OK   | 0x0     | discrete   | Deasserted | na     | na     | na     | na
PSU1_Pwr_Out_OK  | na      | discrete   | na      | na     | na     | na     | na
PSU1_Fault     | na      | discrete   | na      | na     | na     | na     | na
PSU1_Input_Type  | na      | discrete   | na      | na     | na     | na     | na
PSU1_Over_Temp   | na      | discrete   | na      | na     | na     | na     | na
PSU1_Over_Volt   | na      | discrete   | na      | na     | na     | na     | na
PSU1_Over_Curr   | na      | discrete   | na      | na     | na     | na     | na
  • 影響を受ける PSU を取り付け直した後でも問題は解決しません。
New to NetApp?
