メインコンテンツまでスキップ
FlexGroup ボリュームの作成時にNFSv3およびNFSv4.xで64ビットIDを有効または無効にすることを示す警告が報告されました
206
Visibility:
Votes:
1
Category:
ontap-9
Specialty:
core<a>2008889397</a>
Last Updated:
環境
  • ONTAP 9
  • FlexGroupボリューム
問題
FlexGroupボリュームの作成中に次の警告が表示されます。
Warning: You are attempting to create a FlexGroup volume in Vserver "vs0", which currently uses 32-bit FSIDs and file IDs of both NFSv3 and NFSv4.x. This could result in collisions between different file IDs on the FlexGroup volume. Modify the Vserver to use 64-bit NFSv3 and NFSv4.x identifiers before using the FlexGroup volume with the commands
"set advanced; vserver nfs modify -vserver lc-vserver -v3-64bit-identifiers enabled -v4-64bit-identifiers enabled".
New to NetApp?
