NVRAMバッテリ低下が原因で両方のコントローラがシャットダウンします
環境
AFF A250
問題
- 2台の新しいコントローラが取り付けられました
- ONTAP のブート時に、CLIに次のメッセージが表示されます
WARNING: The battery is unfit to retain data during a power
outage. This is likely because the battery is
discharged but could be due to other temporary
conditions.
When the battery is ready, the boot process will
complete and services will be engaged.
To override this delay, press 'c' followed by 'Enter'
- 警告は無視され、ONTAP は強制的にブートされます
CAUTION: Using this appliance without NVRAM
battery backup coupled with a power
failure condition CAN CAUSE DATA LOSS.
Are you sure you want to continue (y or n)? y
Proceeding without NVRAM battery backup.
- コントローラは次のメッセージで停止します
[node-01:monitor.shutdown.emergency:EMERGENCY]: Emergency shutdown: Environmental Reason Shutdown (Battery remain capacity critical)
