メインコンテンツへスキップ
CAIQUM-5783:ONTAP 9へのアップグレード後、AIQUMでリストアするためのSnapshotの内容を参照できません。13.1P6
64
Visibility:
Votes:
0
Category:
active-iq-unified-manager
Specialty:
om
Last Updated:
問題
  • After ONTAP upgrade to 9.13.1P6 >
  • Browsing the source snapshot in AIQUM fails with error:
Data ONTAP reported error code (13114), message: 'Failed to mount volume <volume_name> in Vserver <vserver_name>. Reason: No such process.' (request: '<file-get-file-info> <path>/vol/<volume_name>/.snapshot/weekly.2023-07-30_0015/</path> </file-get-file-info>').
  • zapi-outbound.log:
DEBUG [default task-61571] [service.storage.volume.SnapshotBrowserItemLiveListService|getItems] Received ZAPI response for file-get-file-info from <ONTAP_Cluster_IP>: <?xml version='1.0' encoding='UTF-8' ?> <!DOCTYPE netapp SYSTEM 'file:/etc/netapp_gx.dtd'> <netapp version='1.231' xmlns='http://www.netapp.com/filer/admin'> <results reason="Failed to mount volume "<vol_name>" in Vserver " <svm_name>". Reason: No such process." status="failed" errno="13114"/> </netapp>
  • audit.log:
WEB:in:[<AIQUM IP>]::OnTapApi:Result=Failure:file-get-file-info: {"path":"/vol/<vol_name>/.snapshot/<snapshot_name>/"}
  • ocum_error.log:
ERROR [<user>] [default task-61571] [service.logging.SimpleRemoteLoggingService|logOnServer] [c.n.n.c.u.a.e.ApplicationErrorHandler] Data ONTAP reported error code (13114), message: 'Failed to mount volume "<vol_name>" in Vserver " <svm_name>". Reason: No such process.' (request: '<file-get-file-info> <path>/vol/<vol_name>/.snapshot/<snapshot_name>/</path></file-get- file-info>')
New to NetApp?
